Incra TSLS fence maintenance
bhiebeler
Post by bhiebeler »
I purchase a used Mark 510 with the Incra TSLS system and wonder fence. When I slide the fence I feel and hear the teeth dragging. Also the the micro adjuster does not seem to be moving the fence. Is there any maintenance information to align the system? Is this typical for this?
bhiebeler wrote:I purchase a used Mark 510 with the Incra TSLS system and wonder fence. When I slide the fence I feel and hear the teeth dragging. Also the the micro adjuster does not seem to be moving the fence. Is there any maintenance information to align the system? Is this typical for this?
It is hard to tell what might be wrong but fortunately you have problems with hardware that is supported by and excellent customer service department.
Please make yourself familiar with the Incra web site.
This manual (from that site) should answer most of your questions.
I wish your problem fence was sitting on my Mark V.:rolleyes::)
wallpaperman
Post by wallpaperman »
dusty wrote:It is hard to tell what might be wrong but fortunately you have problems with hardware that is supported by and excellent customer service department.
Thanks Dusty for the PDF manual I have a good collection that I will share with anyone. This on is great.
Cliff
keakap
Post by keakap »
I answered the first iteration of your post before I saw this one; to wit:
With the carriage lock handle in the uppermost position- there are two "lock" positions- does the carriage (fence) move easily thru its total range? [And do both the other positions work as they should?]
And is the 'zero adjust' carriage alignment doohickey set properly?
