Another question: Why are they sold in sets of two? I suppose that, were I a machinist, I would know both answers. I'll bet one of you guys know.
What Are The Threaded Holes For?
I ordered and received a set of 1, 2, 3 blocks. I assume all the holes are to lessen their weight. But, what are the threaded holes for?
Gene
- robinson46176
Gene Howe wrote:I ordered and received a set of 1, 2, 3 blocks. I assume all the holes are to lessen their weight. But, what are the threaded holes for?![]()
1. Bolts...
2. Reproduction...
- stephenrc
- Bronze Member
On the original version of the 123 blocks, it was to bolt them together. The inexpensive ones available today, the non-threaded holes are too small to allow that. They can be used for additional hold downs.Gene Howe wrote:I ordered and received a set of 1, 2, 3 blocks. I assume all the holes are to lessen their weight. But, what are the threaded holes for?![]()
They also can be used to check anything is at 90 degrees. Set a distance of 1", 2", 3" or a multiple. You can also get 2-4-6 blocks.
1981 Mark V 500 upgraded to a 520, w/bandsaw & jointer, HF 8x12, HF X2, HF Wood Shaper, Craftsman 8" table saw & a planer.
Two allows one to prop up both ends of a work piece to an equal height.
The threaded holes allows one to secure them to a way(or whatever suits).
A 'way' is more appropriate to a lathe - the tail stock and 'carriage' slide on the ways. Hence the reference of the ss tubes as way tubes.dusty wrote:It is good that your questions are answered, Gene. But what is a way?
I know the way home. I know way tubes. I know the door way. But I don't know what a way is.
My original mention of 'ways' was meant to apply to a milling machine. The 'table' has slots(yes 't slots') used for mounting jigs and workpieces and are sometimes referred to as way slots. Not being a 'machinist', I may have used the term incorrectly. After all my machine shop 'training' was over a half century ago!;)
- robinson46176
[ATTACH]18966[/ATTACH]
- temp - mill table ways.jpg (12.68 KiB) Viewed 1902 times
Thank You (again)!robinson46176 wrote:[ATTACH]18966[/ATTACH]
And that reminds me of a question I've had since taking up sailing-- You hear people yelling "anchors a way", but I've never heard WHAT. And as long as the way is properly anchored who cares what anchors it, any way?dusty wrote:It is good that your questions are answered, Gene. But what is a way?
