Box in a box (or eye box)
Here is a post from way back in Dec. 2007. https://forum.shopsmith.com/viewtopic.php?p=6926&postcount=6 This post has a snapshot of the making of the box.
Wow! That is a few days over 5 years ago. Guess it wouldn't hurt to review the Box in a Box.
I glued the shaky eyes on the inner box for cuteness and too hide the center hole made by the forstner bit.
There is just two little secrets to making a Box in a Box. First, don't try this without firm clamping! Holding by hand will surely end up with hurting fingers. Second, after finding the centers of the sides of the original block, select your forstner bit and drill the depth slowly. Only drill as deep as you need to show a little light on each side of the inner block. In fact just sneak up on that depth on all 6 sides until you see that the inner block is ALMOST free. Then finish cutting the inner block free with a sharp knife.
Here is a pix of the finished project again.
[ATTACH]19638[/ATTACH]
A funny note to this project - I gave it to my son for a Christmas stocking stuffer. He took it to work to share with the other engineers. They all thought it was a puzzle and tried and tried to take it apart. They also couldn't figure how it got made.
fjimp
Post by fjimp »
Great job. I made a few of those several years ago. I enjoyed making them but nearly lost a finger in the process. Clamping and slow approach with the forstner bit is crucial. I would also add keep your hands away from the drilling process. My block was well clamped and the forstner bit grabbed an edge spinning the block out of the clamps. The 25 mile drive to the ER was a long one. Jim
F. Jim Parks
Lakewood, Colorado:)
pennview
Post by pennview »
Here's a short video on the process of making the cube -- http://www.youtube.com/watch?v=TfV_APBk16Q
Art in Western Pennsylvania
dgale
Post by dgale »
pennview wrote:Here's a short video on the process of making the cube -- http://www.youtube.com/watch?v=TfV_APBk16Q
Good video, although a bit scary a few times how close he puts his fingers to that spinning bit. I'm guessing certain types of wood would lend themselves better to this project - any thoughts on what they might be? He also mentioned hearing of someone who did a cube within a cube within a cube...that would take some fancy clamping to get that inner cube to hold still while you drilled it.
BTW - Chuck, I like the way you cut off the corners on yours - it gives it a better finished look IMO.
joedw00
Post by joedw00 »
Thanks Chuck for re-posting that, and Art for the you tube video.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
dgale
Post by dgale »
This is a good "trick" project as well, although the guy on the video need to buy himself a dado blade. Never tried it but if it really works out like it does on the video, it would result in a good head scratcher to show friends.
http://www.youtube.com/watch?v=fEATei2wewY
joedw00
Post by joedw00 »
That is a good trick, and yes he needs a dado blade. The hole sure is not drilled straight.
Joe
dgale
Post by dgale »
joedw00 wrote:That is a good trick, and yes he needs a dado blade. The hole sure is not drilled straight.
Looks like he used a piece of pine (?) I imagine only certain woods would compress like that after being soaked and then resume their old shape after a re-soaking
burkhome
Post by burkhome »
Thirty-five years ago or so we did "sawdust days" chainsaw demos at a hardware store that I ran. One of the fun things we did was make a ball trapped inside of a cube with a chainsaw. It was a real conversation starter.
Roger, Waupun Wisconsin
saminmn
Post by saminmn »
dgale wrote:Good video, although a bit scary a few times how close he puts his fingers to that spinning bit. I'm guessing certain types of wood would lend themselves better to this project - any thoughts on what they might be? He also mentioned hearing of someone who did a cube within a cube within a cube...that would take some fancy clamping to get that inner cube to hold still while you drilled it.
Just guessing, but I would have the inner one cut free before I cut the middle one free. I may not even start the middle one until I was ready to cut the inner one free.
Sam in Northfield, MN
A day without beer......could have been better :p :D :p
Mark V 500 - S/N 100990, Mark V 510 - S/N missing, SS Band Saw, SS 6" Belt Sander, SS 4" Jointer, SS Scroll Saw, SS DC3300
