What direction does the Power Station output shaft rotate? Looking at the switch side of the power head (for front orientation) my output shaft turns top to the back. I suspect it should turn top to front.
Another way to state the rotation direction. Looking from the output side of the power head mine rotates counter clockwise
The motor can be wired to rotate in either direction.
Note: The motor label picture is rotated 180
[ATTACH]20291[/ATTACH]
[ATTACH]20292[/ATTACH]
Power Station output shaft rotation
- IMG_0542 (800x590).jpg (413.37 KiB) Viewed 1188 times
- IMG_0544 (800x586).jpg (311.24 KiB) Viewed 1195 times
Glenn
- BuckeyeDennis
Thanks for taking the time to reply.BuckeyeDennis wrote:Your suspicion is correct. Mine rotates "top to front", or clockwise when viewed from the shaft end.
I almost said that the bandsaw I have mounted wouldn't work with the rotation reversed. But hey, if I simply flipped the blade around, I could invent the "reverse upcut bandsaw"!
I wonder how flipping the blade would effect tracking?
Glenn
Might be hard to keep it sharp also:Dstumpbuster wrote:Thanks for taking the time to reply.
I wonder how flipping the blade would effect tracking?![]()
Sam in Northfield, MN
A day without beer......could have been better
Mark V 500 - S/N 100990, Mark V 510 - S/N missing, SS Band Saw, SS 6" Belt Sander, SS 4" Jointer, SS Scroll Saw, SS DC3300
