Lower tubes breakdown
I would refer to them as bench tubes, but they do not function as such. They remain part of the 'upper' assembly that includes the way tubes and headstock etc.
There are two tilt locks, one for each 'direction.
[ATTACH]20844[/ATTACH]
The rear end lock cam is retained by a tension pin.
[ATTACH]20845[/ATTACH]
As is the front lock cam that also has the lock handle attached.
[ATTACH]20846[/ATTACH]
The handle is secured to the cam by two screws.
[ATTACH]20847[/ATTACH]
This thread is linked to from https://forum.shopsmith.com/viewtopic.php?t=11373
clamp a.jpg (289.62 KiB) Viewed 1359 times
clamp b.jpg (468.62 KiB) Viewed 1359 times
clamp c.jpg (486.78 KiB) Viewed 1360 times
clamp d.jpg (416.58 KiB) Viewed 1361 times
The two lock levers are identical, but have the opposite pair of holes tapped. This is so each locks in opposite directions
[attach]20848[/attach]
One lever had a bit of damage(PO attempted to remove bullet detent?)
[attach]20849[/attach]
Not pretty, but more 'normal'.
[attach]20850[/attach]
Finally all the parts there are ready for cleanup.
[attach]20851[/attach]
clamp e.jpg (505.92 KiB) Viewed 1359 times
clamp e2.jpg (500.05 KiB) Viewed 1358 times
clamp f.jpg (503.2 KiB) Viewed 1365 times
clamp g.jpg (495.48 KiB) Viewed 1354 times
