Any experience with these tubes?
db5
Post by db5 »
henecle
Post by henecle »
yep... bought mine for I think $35 BIN a few months ago. They work as advertised. :)
Leif
1981 Mark V Model 500 "Shorty"
1981 Mark V Model 500 "Drill Press"
1987 Sawsmith 2000 Ultra
2005 Mark 7 PowerPro Model 520/Bandsaw/Jointer/Pro Planer/Belt Sander/Scroll Saw/Jigsaw/Strip Sander/Universal Tool Rest/Speed Reducer/DC3300/RingMaster/Mortising Package/MiterSled 5000/Biscuit Joiner/Grinding Wheel Guard/Nova G3 Chuck/Lathe Duplicator/SS Air System
2010 Lumber Smith sawmill
CarveWright CNC
"I wish I could remember everything my Dad taught me"
Yes, I have a pair and I like them.
They are heavier and they are straight.
The finish is holding up well but I have had these only a few months. Not long enough to confirm longevity of the surface.
mountainbreeze
Post by mountainbreeze »
I have a pair. They have thicker walls than what you get from SS and as such are heavier. The finish appears to be the same as the tubes that came with my 520 and they are straight. I can recommend these tubes.
Bill
Mark V 520 50th Anniversary Edition, Planer, Jointer, Bandsaw
fredsheldon
Post by fredsheldon »
Do they exert undo stress on the main table when extended all the way out to the left beyond the band saw with something heavy on the extended floating table without using the adjustable support legs?
Fred Sheldon
The Woodlands, Tx
fredsheldon wrote:Do they exert undo stress on the main table when extended all the way out to the left beyond the band saw with something heavy on the extended floating table without using the adjustable support legs?
Absolutely. The laws of physics do apply. It is for that reason that my old tubes were bent.
I will attempt to avoid that condition with these tubes even though they are heavier. They are straight and I would like to keep them that way.
db5
Post by db5 »
dusty wrote:I will attempt to avoid that condition with these tubes even though they are heavier. They are straight and I would like to keep them that way.
Well, that settles it then. I need to order these before the offer expires - midnight tonight or is it the 16th? Thanks for the feedback.
The seller still has 9 sets available.
May 13 15:04
frank81
Post by frank81 »
JPG40504 wrote:The seller still has 9 sets available.
May 13 15:04
If you want to save a buck and he has 9 sets available try e-mailing him and making him an offer. I do that all the time on eBay Motors to salvage shops and most of the time it works. Not too many people looking for heavy duty SS tubes, the 9th set is going to be relisted many times over.
