My New Undermount Storage Solution
Hi all,
I just finished my undermount storage system and thought I would let you guys see it. The backbone is two lengths of angle iron recycled from a metal bed frame and bolted to the support legs. These had the extra benefit of stiffening the Mark V. Underneath these I bolted on a lightweight cabinet that holds two boxes that contain all my associated equipment. A third storage space is open for general storage. On top of this I mounted a table on which I added storage for the fence, my crosscut sled, throat plates, and miter gauge. On the back of the table I added magnets to hold my blades and a cutoff PVC pipe to hold my extension legs. What do ya'll think?
- Before Table.jpg (81 KiB) Viewed 14560 times
- back with table.jpg (87.97 KiB) Viewed 14505 times
- Box storage.jpg (70.45 KiB) Viewed 14491 times
- Front with table.jpg (90.03 KiB) Viewed 14521 times
- fence storage.jpg (67.88 KiB) Viewed 14481 times
- fredsheldon
I think that setup would solve my jumping all over the place when turning large out of balance blanks when turning bowls
Nice job.
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
Very neat idea!!! I like the bed rails and will look into them for mine so i can weight the unit down for turning....I have some rail road rail pieces..
And I thought I was the only one had that problem??? The other little thing I run into is when using the chuck it's hard to get the inside of a project done without a lot of vibration...
thanks, bill
fredsheldon wrote:I think that setup would solve my jumping all over the place when turning large out of balance blanks when turning bowlsNice job.
thanks, bill
Brick1
Titusville, Florida
stallion143
- Bronze Member
- Ed in Tampa
cooch366
Great idea
Wow what a great idea and MAJOR space saver! A great space for storing the big stuff in an out of the way place,close.
I can see adding a piece of plexiglass as a top, to help keep "stuff" out, and to help with keeping it a little cleaner. We have enough to clean up now:D
Great idea and design.
Steve
Steve
