Does anyone use a momentary/pedal pedal switch on a shopsmith?
There are obviously problems if it shuts off at high speed, but how else does it work. Was considering adding one for when I am turning things so that would be low speed.
pedal switch on shopsmith
johnwilliamson062
I think that would be 'reasonable', but why? The 'normal' switch is close at hand, and so be your hand.
You add the possibility of inadvertently stepping on the switch and starting it when not intended.
- fredsheldon
One thing I like about the PowerPro is it stops immediately by itself if you get a jam or hung up on a turning. There is a very quick squeak from the belt in some cases but most of the time it just stops until the jam is cleared.
Fred Sheldon
The Woodlands, Tx
The Woodlands, Tx
johnwilliamson062
I haven't found a need for foot switch over the past 30+ years I have been using my Shopsmith. I find I walk around moving stock to be able to keep my foot in one place. Instead, I installed a large "stop" switch to my headstock and find it very easy to turn it on and off when needed.
[ATTACH]21802[/ATTACH]
- 20915-04-500.jpg (38.31 KiB) Viewed 2114 times
Abraham Lincoln
Abraham Lincoln
- terrydowning
A foot switch and turning are not a good idea. You will find that you often need to adjust your footing to get the correct tool positioning, especially for bowls. Not to mention being in a static position to operate the switch for long sessions could get tiring. Use the switch or rig a remote as Animus has described.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
Terry
If you think reaching for the power switch is 'inconvenient', try adding a foot switch (deadman or toggle) to a power pro.
:D
