Planer Stop & Final Thickness Gauge Ledge
ldh
Post by ldh »
I have used my SS 12" planer for over thirty years and it has served me well, but recently I found myself wanting a bit more control over the machine. A couple of pictures should explain how I set for final thickness with a caliper and use the stop rod to end up at that setting.
ldh
[ATTACH]21941[/ATTACH]
[ATTACH]21942[/ATTACH]
BigSky
Post by BigSky »
ldh wrote:I have used my SS 12" planer for over thirty years and it has served me well, but recently I found myself wanting a bit more control over the machine. A couple of pictures should explain how I set for final thickness with a caliper and use the stop rod to end up at that setting.
ldh
Very neat. Excellent solution. One question though. How do you go about zeroing?
MarkFive510
trainguytom
Post by trainguytom »
Cool idea. I love to see the various innovative, yet cheap & simple ways to improve tool functions.
My dad's 1951 10er, 2 more 10er's, same vintage, a Goldie MK5, a 510 shortie with 34inch tubes, bandsaw, jointer, jigsaw, belt sander, a ton of small SS goodies and still looking...you just can't have enough Shopsmith stuff
ldh
Post by ldh »
BigSky wrote:Very neat. Excellent solution. One question though. How do you go about zeroing?
The minimum thickness that the machine can plane to is 1/8", so I installed the ledge to read 1/2" on my caliper at the minimum thickness setting on the SS. The 1/2" measurement on the caliper would yield a 1/8" thickness, so that is the relative zero. Any thickness above 1/8" would have a setting of
+3/8 on the caliper. For instance setting the caliper to 3/4" and bringing the table to this setting then adjusting the stop to the table will yield a thickness of 3/8" time after time. As you can see I zero the caliper on zero and just have to remember to add 3/8" to the caliper when setting the table. Most of the time I use a fractional caliper, but when I really really need to get even closer I use a caliper in thousands or a feeler gauge under the stop. If you build one of these you will quickly find how easy it is to get that perfect
.1875 thickness you needed.
ldh
With a digital caliper you could 'zero' it at .375 and it would then be direct reading.
