Hi Gang;
I finally got around to trying my hand at making some segments to start doing some segmented bowls. I only made one ring at this time and incorporated it into a solid bowl of unknown species. The ring is a strip of yellow heart laminated to a piece of purple heart and then cut into segments. Each segment was then flipped to obtain the checkerboard pattern. The bowl is still mounted on my Delta lathe because the 520 is still set up with the jig that needs a bit more tweaking.
BIll V
[ATTACH]22850[/ATTACH]
[ATTACH]22851[/ATTACH]
segments anyone?
segments anyone?
- bowl with ring one.jpg (70.29 KiB) Viewed 1092 times
- bowl with ring two.jpg (76.6 KiB) Viewed 1088 times
- BuckeyeDennis
Now that is downright purty.
I may take up bowl turning yet!
- mountainbreeze
