Question on set up- Incra I Box Jig
ChrisNeilan
Post by ChrisNeilan »
I just received an Incra I Box Jig, looks like it is well made. In the setup instructions the instructions say to set it up depending on if the saw is left or right tilt. Well, I'm guessing that a Shopsmith is neither. Any recomendations?
Chris
ChrisNeilan wrote:I just received an Incra I Box Jig, looks like it is well made. In the setup instructions the instructions say to set it up depending on if the saw is left or right tilt. Well, I'm guessing that a Shopsmith is neither. Any recomendations?
Chris
The table tilts right so tis the same as an arbor tilting left.
Truth be known, what this is really about, is which side of the blade is 'constant' and which side 'grows with the blade width adjustments.
The jig is assembled two different ways depending upon the blade configuration. The SS arbors are constant on the left(headstock side) and the kerf grows to the right as the blade size is increased.
ChrisNeilan
AHHHHH, I see.... I was overthinking it, Thanks
ChrisNeilan wrote:AHHHHH, I see.... I was overthinking it, Thanks
No, I 'think' Kreg was under thinking and used blade tilt direction as part of the instructions, when they should have been referring to arbor nuts.:rolleyes:
SDSSmith
Post by SDSSmith »
JPG40504 wrote:No, I 'think' Kreg was under thinking and used blade tilt direction as part of the instructions, when they should have been referring to arbor nuts.:rolleyes:
Wonder what Incra was thinking?:cool:
Rob in San Diego
While you are setting up your ibox you might want to read this post, it might answer a couple other questions you might run in to.
https://forum.shopsmith.com/viewtopic.php?t=12807
SDSSmith wrote:Wonder what Incra was thinking?:cool:
I 'think' INCRA(yaa I got that wrong:o) was thinking what is the most visual thing regarding arbor 'ends'. Tilt was the most obvious.
Again we gots a different animal.
