I read about all the problems and hassles-- but I found a set of Shopsmith Maxi-Clamps.
The story is more interested than using the clamps
I have been in my house for almost two years, it came with a shop and some tools.
on this one shelf sat a small box of little boxes that you organize small nuts and bolts in them, plastic store brought, everyone has seen them, maybe all own one.
So since the pervious owner box was smaller then mine, I put his on top of mine on the shelf.
Today doing something I look over and saw the shelf and said "why would he build a box for a shelf". "I tapped underneath--it even has a bottom"!
so I take off the organizers and the top has hinges and sure enough inside was a Shopsmith Maxi-Clamp system with booklet.
If only there was a BIG box laying around with a SS in it.
found something
farley wrote:I read about all the problems and hassles but I found a set of Shopsmith Maxi-Clamps.
So since the pervious owner box was smaller then mine, I put his on top of mine the shelf.
Today doing something I look over and saw the shelf and said "why would he build a box for a shelf". "I tapped underneath--it even sas a bottom"!
How long have you been in the house? Only two years. Keep looking.
Good luck, farley!:):)
gr8mesquite
