Cheating big time on the lathe
gr8mesquite
Post by gr8mesquite »
Anybody ever use one of these?
http://toolfanatic.com/p/Manual-Lawn-Ae ... 858QbHCe00
Does it require a huge motor with an unusual amount of torque, or will a 3/4hp lathe motor turn it?
Also, can you remove the screw point after a while to get a flat bottom?
Thanks
Jerome
"Life is what happens to you while you're busy making other plans."
gr8mesquite wrote:Anybody ever use one of these?
http://toolfanatic.com/p/Manual-Lawn-Aerators/B003GUH4SC/detail/Steelex-D3654-4-58-Inch-Heavy-Duty-Forstner-Bit-with-Screw-Tip.php#.U858QbHCe00
Thanks
I do not think power/ is the issue, speed is more likely a deterrent.
What is 'magic' about 4 5/8"?
Looks like the point may be removable.
terrydowning
Post by terrydowning »
JPG40504 wrote:I do not think power/ is the issue, speed is more likely a deterrent.
I agree, keep the speed as slow as it will go.
The SS Motor should handle it. It will heat up so take your time.
Many people use forstner bits in their lathes for hogging out bowls and such.
I have also seen people use a large forstner bit (same diameter of a face plate) to hog out much of a bowl blank before even putting on a lathe and then attach a faceplate for turning the outside of the bowl and the tenon. Very effective. on the demonstration I have seen.
Terry
Public Photos of Projects
http://sdrv.ms/MaXNLX
gr8mesquite
Nothing "magic" about 4 5/8"--it just happens to be the largest Forstner I've come across on the web.
I I realize that the screw is adjustable/perhaps removable. The mfg.'s description of the item points out that the screw helps in the cutting by pulling the bit into the wood. I'm wondering whether drilling would be as easy/accurate without the screw, in an effort to eliminate the screw hole. I would of course start with the screw, and possibly remove it at a certain depth.
I'm looking at 4 5/8" on a ruler, and I'm boggled by the amount of wood that could be hogged out on the inside of a turned bowl. It could make turning the inside really fast and accurate, although I refer to it as "cheating." :)
Jerome
Seems like a very teeney tiny pointed screw for such a large bit!:rolleyes:
beeg
Post by beeg »
gr8mesquite wrote:I'm wondering whether drilling would be as easy/accurate without the screw, in an effort to eliminate the screw hole. I would of course start with the screw, and possibly remove it at a certain depth.
I wood think if ya drill the hole deep enough, then ya could use the sides of the hole as a guide, with the screw removed.
"Wild Bad Bob"
Post by "Wild Bad Bob" »
I have never used a bit that large in dia, but have some in the 1/2" to 1 1/2" wood boring bits with a similar screw threaded point, they tend to want to take control of the "boring" for lack of a better word at the moment, and pull itself into the wood as long as it is turning do to the threads acting as a screw, I found them very hard to control the depth of the boring.
Jack Wilson
Post by Jack Wilson »
I have a 2-1/2" version of that and the screw is removable.
SS Mark 7 PowerPro, 2 SS Bandsaws, SS Belt Sander, SS Jigsaw, 13" Steel City Lunch Box Planer, SS Jointer, Jet 22-44 Drum Sander
rcplaneguy
Post by rcplaneguy »
The link says it is for lawn aeration?
John
gr8mesquite
rcplaneguy wrote:The link says it is for lawn aeration?
Obviously in the wrong category. Wouldn't be much lawn left with 4 5/8" holes all over the front yard.:D
Jerome
