Jigsaw guidepost and lower backup
SSwanabee
Post by SSwanabee »
Hello all - I'm brand new to this forum and so far over the past few days I have gained a wealth of knowledge about Shopsmith's and their accessories.
I obtained a Shopsmith last week that was built in the mid 80's and I am slowly taking it apart and cleaning it up. Working on the jigsaw now, thankfully I read the posts about it needing oil in the reservoir or I would never have known.
My question is what is the guidepost for? I don't have the 'lower backup', can someone tell me what material it is made of and is it essential for the jigsaw?
I am also missing the instruction manual, it's the model with the round tubular arm. Does anyone know where I can download one, all the links I've found no longer work.
Thanks,
Patrick
algale
Post by algale »
SSwanabee wrote:Hello all - I'm brand new to this forum and so far over the past few days I have gained a wealth of knowledge about Shopsmith's and their accessories.
My question is what is the guidepost for? Not sure what the "guidepost" is, but the "guide rod" holds and positions the upper blade guide. I don't have the 'lower backup', can someone tell me what material it is made of and is it essential for the jigsaw? The manual I have says it is only for saber sawing (i.e. when you use a saber saw blade and don't use the upper chuck). I have no idea what material it is made of. It looks vaguely fiberous.
I am also missing the instruction manual, it's the model with the round tubular arm. That's the model 610. Does anyone know where I can download one, all the links I've found no longer work. I have a pdf copy of an ancient (1965) manual but it is too large to post. If you PM me I can send you a copy. The photos probably aren't as clear as the later manual, but it should give you what you need.
Thanks,
Patrick
See my responses, above. And welcome to the forum!
anmius
Post by anmius »
I have attached a reduced file size model 610 jigsaw manual for your reference.
Magna 18 inch Jigsaw Model 610 Manual compressed.pdf
(1.81 MiB) Downloaded 2643 times
Abraham Lincoln
SSwanabee
Post by SSwanabee »
Thanks guys, exactly what I needed!
Patrick
