Sanding Belts
delong94
Sanding Belts
Post by delong94 »
Has anyone used the 6 x 48 belts available from Harbor Freight on their belt sander? They are a good deal at $14.99 for the 5 pack and they have the 12 inch discs for $5.99 for a 2 pack. You get a better deal with the 20% off coupon.
timsturnings
Post by timsturnings »
I have no experience with those belts from HF but for that price I think I would give them a try and possibly report on here of how they worked. JMHO.
Tim.
Seven days without turning makes one weak. :o
1952 Shopsmith 10er(restored)with Speedchanger,1952 Craftsman 10" table saw,Jet 1014 lathe(VS),HF VS 95607 Lathe,Craftsman Drill Press,55 Gal. Tornado Dust Collection System,Shop Wide Overhead Vac piping,WC slow-speed grinder,Wolverine sharp. system,Grizzly GO580 14" Bandsaw,Rikon Disk/Belt sander,HF Pressure Pot, JB 7 CFM Vac pump,TurnTex Stabilizing Chamber. (My 16' X 20' shop is full to the gills)
Gene Howe
Post by Gene Howe »
I've used their 3X36 belts and found them satisfactory.
Gene
"Wild Bad Bob"
Post by "Wild Bad Bob" »
Delong94
I have a clone SS belt sander from Menards, I bought used, had a belt on it. I read on either the SS site or in there book, about "crowning" belts other then SS, so that they track better if I remember. I have not needed to do that, nor have I put a new belt on mine, so only passing on what I read, for you to be aware of.
wa2crk
Post by wa2crk »
I have used a few and put the rest in our community wood shop and reordered some from SS. The seams on the HF belts just seemed to be a bit too "clunky" to suit my taste. They had a very annoying thump whenever the seam came around that caused the work to jump a bit.
