Bandsaw - Mk V vs VII compatibility?
Mike vonBuelow
Post by Mike vonBuelow »
So, is there a bandsaw made for the Mk VII ?
Or can I get some sort of an adapter for my Mk VII to enable it to fit ?
Or does it have to do with the endcap spacing ?
Bottom line question - how can I get a bandsaw on my Mk VII ?
Proud 24-yr USAF Veteran
COMPUTER: Dell Optiplex 620 - XP
LASER HARDWARE: Pinnacle 25W Mercury
CNC HARDWARE: Lumenlab MicRo CNC
WOOD TURNING HARWARD: ShopSmith Mark 7
SOFTWARE: Corel X3, CS4 Suite, Photoshop Web Suite CS3, Solidworks
FIRMWARE: My brain
wa2crk
Post by wa2crk »
The bandsaw should fit a VII or a 7 or a MK5. Are you having trouble lifting the machine to the vertical with the bandsaw attached?
You may need the offset mounting tubes for the bandsaw.
Also if you do have the offset tubes ( they look like two tubes slightly offset from the other ) and if they are misaligned you will have to loosen the set screws in the bandsaw tubes so they line up with the holes in the headrest and then line up the bandsaw in both the vertical and horizontal so the power coupling will line up. Check the manuals for the bandsaw and/or the MKVII/5 for details.
Mike vonBuelow
No, haven't gotten one yet - just making sure I don't need any adapters to get one
Thx!
FIRMWARE: My brain
db5
Post by db5 »
Mike:
Any bandsaw for the shopsmith will work. Just make sure your stop collars are set correctly. A bandsaw with stop collars should cost $150-$175 if it is in good condition. Perhaps less if you shop.
Although the spt mount is dimensionally the same as a M5/V on a MVII, the end castings are permanently attached to the bench and way tubes and therefore go with them when raised to vertical in either direction.
This means spts must be dismounted to raise to vertical(unless you do not mind them hanging over yer head!:eek::eek:.):D
skou
Post by skou »
&quot wrote:This means spts must be dismounted to raise to vertical(unless you do not mind them hanging over yer head!:eek::eek:.):D
Or, smacking you in the knee/shin area. :p
steve
10 ER, stripped down.
Mike vonBuelow
I do not plan to use anything that requires verticallity (or is it vertical-ness?) :cool:
FIRMWARE: My brain
