Other Uses For Molder/Dado Arbor 505506?
Other than serving as a dado arbor or a molder arbor, what other uses are there for the molder/dado arbor 505506 pictured here:
[ATTACH]26787[/ATTACH]
I've got three of em. The first I acquired to use with my stacked dado set. The other two arbors came with two molder heads I recently acquired.
I've only got one Shopsmith. So I am going to keep one of the newly acquired molder heads (can't think why I need two) and one of the newly acquired 505506 arbors to use with it (so I don't have to swap it with the arbor I use for my dado stack).
That will leave me with one molder with a dedicated 505506 arbor, one stacked dado head with a dedicated 505506 arbor and one "extra" 505506 arbor.
So I am thinking of separately selling the "extra" arbor. The question of whether there are other uses for a 505506 arbor is so I won't later be kicking myself when I find out I "needed" it.
- MoldingArbor.jpg (26.82 KiB) Viewed 4541 times
I assume its a 5/8 arbor, so for that 80 tooth 10" sawblade you always wanted?
The sickness is spreading:
Mark V greenie 1954
Mark V goldie 1962 (I think)
Mark V grey 1978
Shopsmith attachments: 2 Jig Saws, Bandsaw, Jointer, Planer. Shaper tooling, many adapters, arbors, etc.
50s vintage Craftsman table saw
50s vintage Craftsman band saw
Mark V greenie 1954
Mark V grey 1978
Well ya could it for standard saw blades.
It is 5/8 inch arbor. And while there's no obvious reason it would not work with any 5/8 inch bore saw blade, Shopsmith claims it isn't for use with regular saw blades (maybe because they sell a 5/8 dedicated saw blade arbor # 555608).wodnek wrote:I assume its a 5/8 arbor, so for that 80 tooth 10" sawblade you always wanted?
I have extra dado/molder arbors with dado blades set for specific width that can be mounted quickly on the 520 saving me a lot of setup when changing dado widths. When I get rid of a shopsmith accessory I find that I need it the next day.algale wrote:Other than serving as a dado arbor or a molder arbor, what other uses are there for the molder/dado arbor 505506 pictured here:
LDH
OK, now i know why you don't use the longer arbor on a 10" saw blade. It catches on a table brace, which blocks the full range of motion of the blade.
(i learned that about 30 minutes ago)
Mark V greenie 1954
Mark V grey 1978
Mark V greenie 1954
Mark V grey 1978
wodnek wrote:OK, now i know why you don't use the longer arbor on a 10" saw blade. It catches on a table brace, which blocks the full range of motion of the blade.
Which is why the extra spacers are important. That nut is very large. So consider a 'thinner' nut.
I would keep it as I have kept everything else that is duplicated/currently having no dedicated purpose.
