Drill Chucks
gr8mesquite
Drill Chucks
Post by gr8mesquite »
Does anyone know where I can find a set screw mount drill chuck for the SS spindle that can take a shanks up to 5/8" ?
Thanks
Jerome
Re: Drill Chucks
NOPE!
However adapters can be used to get there.
5/8" bore is unfortunately not common.
Re: Drill Chucks
Shopsmith introduced a new keyless drill chuck that fits that bill.
Part number 556273 selling for $130.21
Re: Drill Chucks
Whoops!! Forgot about that one! :(
gr8mesquite
Re: Drill Chucks
Thanks for the info, but $130 (plus shipping) is a bit pricey, and is overkill for my project. I need to find a reasonable alternative.
Jerome
gr8mesquite
Re: Drill Chucks
JPG--do you know of adapters that might work?
Jerome
Re: Drill Chucks
Perhaps if we knew what you needed it for we might be able to advise better. There might be other ways of doing a project that would not require a larger chuck?
Pretty resourceful group here, we might surprise you with we as a group can come up with.
Re: Drill Chucks
gr8mesquite wrote:JPG--do you know of adapters that might work?
Jerome
For starters we need to know what the drill chuck is.
Some have a tapered bore, and others are threaded.
And the purpose is? ;)
i.e. what do you need to 'chuck' that is 5/8"? If it is a 5/8" shaft, a 5/8" coupler would suffice.
forrestb
Re: Drill Chucks
Post by forrestb »
You might check out routing bits. I think Whiteside makes a ¼ inch shank bit that has a ⅝ cutting diameter. Might be something you could use.
Forrest
gr8mesquite
Re: Drill Chucks
I realize that this is a resourceful group--that's why I posed the question here.
So, I want to buy a 1 1/2" plug cutter ( http://www.amazon.com/gp/product/B0017Q ... 0LWTFI0BL8 ) which has a 5/8" shank.
Right now the only option I'm seeing is to flatten the shank and get a
5/"8-to-5/8" set screw coupler.
I would welcome any other ideas.
Thanks
Jerome
