10er small jointer cutterhead..must be missing something
robster
Post by robster »
On the 10er I have these 3 pieces in the photo. The arbor I thought would fit the little jointer cutter head but its not long enough or thick enough. What am I missing here. I looked at the old 10er catalog and this seems to be the right part but no...
Re: 10er small jointer cutterhead..must be missing something
The cutter will mount directly on the quill shaft.
If you insist on using an arbor, a 5/8" long enough one is required.
robster
Post by robster »
Duh, your right! Now that I look closer at the intructions I see it is directly mounted to the quill shaft...My bad. Thanks!
