WI-FI TOOL
WI-FI TOOL
Hoping someone here knows of a good(free) wi fi signal diagnostic program that works for B/G/N access points.
Simultaneous results from multiple Access points required. Think Motel like with several close by.
rjent
Re: WI-FI TOOL
Post by rjent »
JPG wrote:Hoping someone here knows of a good(free) wi fi signal diagnostic program that works for B/G/N access points.
What are you trying to "see"
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
Re: WI-FI TOOL
Just returned from a board meeting for a time share owners meeting. Recently had installed a wi-fi system in 50 units. Complaints are currently still rampant!!!
IMHO the location chosen for the APs is asinine(at an extreme 'end' of the units).
I 'think' the responses from the 'provider' we are getting are BS.(moving to a central location will not help!!!)
I merely want to be able do do some analyzing/evaluating myself.
nuhobby
Re: WI-FI TOOL
Post by nuhobby »
BigSky
Re: WI-FI TOOL
Post by BigSky »
Some of the units must be at the "near end". Is the reception excellent there? Is there a limit for how many units can be serviced by a single AP???
rjent
Re: WI-FI TOOL
Post by rjent »
JPG wrote:Just returned from a board meeting for a time share owners meeting. Recently had installed a wi-fi system in 50 units. Complaints are currently still rampant!!!
I use(d) this. Along with our dialup access, our direct T1 connections, and our proprietary wireless high speed access over a 500 square mile radius, the Hotspots could always be the most troublesome.
Try http://wvw.xirrus.com/wifi-inspector xirrus. It snifls the air (like smokey the bear :) ) and gives you the signal strength, mac address, even the brand of AP of the radio it "sees".
Try it, it may do what you want .... :D
Dick
1951 jigsaw X 2
Re: WI-FI TOOL
BigSky wrote:Some of the units must be at the "near end". Is the reception excellent there? Is there a limit for how many units can be serviced by a single AP???
As installed, one AP/unit. Yes they work well at the 'near end'. Trouble is, that is in a remote corner with (multiple)concrete walls between it and more accessible(likely desired) areas.
Re: WI-FI TOOL
rjent wrote: . . .
Looks like a perfect fit!!!!
Thank You!!!!!!
I am suspicious that since they(APs) are in closer proximity to each other than the far reaches of their unit that may be causing them to squabble over channels.
Will be a while before I will be back down there to try this out.
Fun sniffing my neighbors in the mean time! :D(no malice intended!!!!)
rjent
Re: WI-FI TOOL
Post by rjent »
JPG wrote:
rjent wrote: . . .
Thank You!!!!!!
You are welcome ...
Sniffing your neighbors is fun ..... :p
Dick
1951 jigsaw X 2
BigSky
Re: WI-FI TOOL
Post by BigSky »
Could you use 'repeaters' to get out from behind or around the barrier walls.
