BS blade tensioning.
How can I tell if my part#12 502690 Tension Indicator Scale is set correctly? I think I'm getting too little tension on that scale.
Re: BS blade tensioning.
Beeg
The procedure is on page 12 and 13 of the bandsaw manual. If you don't have the manual there is one posted on the SS website. Procedure is quite simple.
ERLover
I go by the rule no matter the band saw, and dont trust the scale, and it depends on the size as far as a 1/4 or 3/8 1/2 ect, flick it with your finger like a qetuar string, if it hums it is right.
Thanks for the info people.
I just tighten a bit, turn it on and continue to tighten 'til the blade quits fluttering.
PS...Since the cover needs to be on while the BS is running, I drilled a hole in the case for access for the hex wrench.
I can't get a single one of my band saw blades to hum. When I pick mine like a guitar, they all twang. But that is NOT how I adjust tension. I do it like Gene Howe suggests. Adjust it til it quits fluttering but then I add about a quarter turn.ERLover wrote:I go by the rule no matter the band saw, and dont trust the scale, and it depends on the size as far as a 1/4 or 3/8 1/2 ect, flick it with your finger like a qetuar string, if it hums it is right.
