How to connect a ShopVac to SS?
wgander
I'm seeking ideas for a way to connect my ShopVac to my SS lower blade guard. I didn't have enough space to bring my Dust Collector to PA and haven't been able to find an adapter that will fit both tools. (The Shop vac is a 1 1/4" hose.)
- crousetrodomis
Well, call it what you want, but mine's quite rigged. I went to Lowes, bought a 2 1/2" hose which should fit your Shopvac (female adaptor on the actual vaccum should be 2 1/2" but then the hose necks down to 1 1/4") and ran it over to the dust port. It does not fit "snug" so I drilled 2 *SMALL* holes in both the Shopvac hose and the dust port where I could place a pin through to hold it all together. That being said, it works, it was cheap and until I can find the money for something better, its what will do.
NOW, when I need extra hose, I use the 2.5" hose as described BUT on the end that normally goes to the shopvac I place a 2.5 adaptor that necks down to 1.25", then take the 1.25" hose and place it back onto the shopvac as normal. (later if you would like, I can go out, snap some pictures of the Greek tragity and post it here tommorrow; just dont tell anybody, i'm not proud of it
"Man Cave" powered by Craftsman, ShopSmith and Kreg
Muncie, IN
Muncie, IN
Supported by Band-Aids and a back-up tourniquet
How to connect a Shopvac to SS
My Shopvac has a 1 1/4" hose also but the port on the vacuum itself is 2 1/2" and fits onto the the DC3300 hose. Do different Shopvacs utilize different connection methods?
The hose laying off to the right of the Shopvac is the Shopvac hose.
[ATTACH]1493[/ATTACH]
- The Shopvac Connection.JPG (152.4 KiB) Viewed 29677 times
brown_hawk
Have you thought of tearing down the 3300 and then putting it together when you get to PA? In pieces, you could fit them in spaces that are otherwise wasted.
If you do take it apart, do it outside. Put the nuts and bolts back in one of the holes, (base, top,etc) with a piece of tape on the threads to keep the nut from unscrewing due to vibration. Also, use masking tape to label the parts. (Probably unnecessary, but why take chances?) And put the filter inside a plastic bag!:D
Otherwise, there is good advice above.
Hawk
Hawk
Dayton OH and loving it!
(Except they closed the store.
After taking a photo for the resonse to wgander's post, I decided to park my Shopvac in a new location. It just might stay there for a short while. I'm going to use it as a dust collector just to see if it works. As a vacuum, the Shopvac certainly performs well.
[ATTACH]1494[/ATTACH]
Wouldn't it be nice if the DC3300 would fit in that unused space under the Mark V.
- Shopvac vs DC3300.JPG (146.85 KiB) Viewed 29667 times
wgander
shop vac...
Thanks for the ideas; I'll have to check the diameter of the input port of my shop vac.
I'm already in PA. We spend our summers here, traveling by motor home. We towed our minivan and I brought the Shopsmith, jointer, strip sander, ring master, owners manuals and odds and ends. I was concerned about weight, so I didn't bring the Dust Collector or the rest of my tools.
I have a nice shop here and a lot of very old hand tools that I inherited, but cannot afford to buy duplicates of what I have in CA.
- chrispitude
My old Shopvac had the 1 1/4" hose. I decided that this was an indicator that the airflow was not sufficient to carry debris up a 2.5" hose, so I sold the old one on craigslist and bought this one:
Shop-Vac 16-Gallon 5.75-Peak HP Pump Wet/Dry Vac
This new Shopvac comes with a full 2.5" hose, and has way WAY more suction than my old one. This was very evident when using the wide floor cleaning attachment to clean the garage floor. The new Shopvac really performed a lot better than the old one. The end of the 2.5" hose fits right into the dust collection port, but is a bit loose. A single layer of electrical tape around the end of the Shopvac hose solved that problem.
click here for picture
As a bonus, the new Shopvac comes with the built-in water pumping feature (for emergency sump pump duties) which I've wanted for a long time.
- Chris
- Chris
brown_hawk
[quote="wgander"]Thanks for the ideas]
I used a small 2.5 hose Shop Vac for years before I got the 3300. The only thing I would be hesitant about would be the Pro Planer. Since you didn't bring that, the shop vac should be fine. Get the paper filters and empty it early and often.
When I used mine, my major problem was forgetting to empty the 5 gal. bucket.
Good Luck,
Hawk
Good Luck,
Hawk
- chrispitude
I'd like to put a ClearVue Mini cyclone collector in line with my Shopvac:
ClearVue webpage
They have a video of it in action on their site.
- Chris
ClearVue webpage
- Chris
