Shop Made Clamp System
gatheringsplinters
Post by gatheringsplinters »
Greetings!
Awhile back I I found myself in need of a small, light duty clamping jig. I drew up a quick sketch and made this with a plywood and wood screws. It has proven way more useful than I could have imagined. At some point I'm gonna rework it and make one specifically for the drill press.
Clamping Jig.png (834.84 KiB) Viewed 3860 times
Jig in Use.png (720.12 KiB) Viewed 3860 times
Mark V 500 (1984) - Shopsmith Bandsaw (Older Model with Cast Iron Table) - Shopsmith Jointer
Woodworker Level: Beginner
Boulder Colorado
Instagram: gathering_splinters
Youtube: gathering splinters
ERLover
Re: Shop Made Clamp System
Post by ERLover »
So what does it do? Pics did not disciple anything special?
Skizzity
Re: RE: Re: Shop Made Clamp System
Post by Skizzity »
ERLover wrote:So what does it do? Pics did not disciple anything special?
A wooden vise using bar clamps.
gatheringsplinters
Yep, that's pretty much what it is. The nice thing is that I can move it between machines and clamp it to their work table for various purposes.
Boulder Colorado
It helps to make square boxes square; i.e. parallel sides paralle.
Neat little jig.
TomH
Post by TomH »
Genius! When are you going to post the plans? :)
Tom
Making scrap wood with style!
oldiron
Post by oldiron »
Nicely done! If you ever build another, I wonder if adding a second set of miter slots perpendicular to the set you have would add even more versatility to the jig?
It could do a two way glue-up, However, What you have built is very nice!!!!!!
gatheringsplinters
Thanks guys,
Necessity is the mother on invention LOL. I'll see if I can find my written plans and I'll scan them for ya.
There are a few things I'd do differently but it works for now. I'm sure I'll make at least one more for the drill press that can be drilled through.
Boulder Colorado
