Finished Bubinga bowl
masonsailor2
Finished up the Bubinga bowl today. Bubinga is interesting wood. Very nice grain pattern to it.
Paul
Paul
- image.jpeg (221.47 KiB) Viewed 4963 times
- image.jpeg (158.33 KiB) Viewed 4963 times
- image.jpeg (220.26 KiB) Viewed 4963 times
- image.jpeg (214.89 KiB) Viewed 4963 times
Re: Finished Bubinga bowl
Very nice! I haven't had much shop time the last couple of months but this is inspiring!
Your project and your manner of achieving it are most impressive!
Chris
Chris
ERLover
Very nice!!!!!
As you have observed, Mason, - Agreed - That is a beautiful piece of wood and a gorgeous turned bowl! Congratulations on your work!
Of particular notice is the smooth transition between the sides and the bowl bottom. Very Nice!
Job well done!!!! You should be very proud of an outstanding bowl......
So, The question is, How do you plan on using it???
masonsailor2
The bowl is for one of my oldest friends who I believe will be using it as a fruit bowl. She requested that profile from an earlier bowl I had made and in a dark wood.
Paul
Paul
Very cool looking bowl. Nice work. Did you use a food safe finish?
masonsailor2
I use Danish oil finish almost exclusively unless it is obviously going to be used for direct food contact in which case I use mineral oil. This one I used Watco.
Paul
Paul
