Knowlegde needed!!
ERLover
Knowlegde needed!!
A bit torn where to post this, because it is a multi question and comment.
I set up shop at moms with some CL used stuff instead of the rent an hour shop, time wise and there time wise was a better deal and theirs was money down the drain, here I may have duo machinery at home I an always sell what ever and get some return on it.
That said, I went and got at my wood provider today some 6/4 Hard Maple and some sheets of Baltic Birch and a piece of White Ash. The Maple is to make some reinforced/trestles footings for that Wood Work bench I bought, the BB for a drawer, and the WA for the face of it.
To the point, I am using a SS jointer on a 1/1/8 HP SS, with sharp blades, I was impressed, .63 wood density as WA and Oaks, but grain structure makes a bit of difference also. I only take a 1/32 ish cut at a time, doing edges. Silky smooth edges and my normal feed rate, nothing slow, I go by sound and resistance. The pieces were 3" high, a bit too much for the fence. I want to add something to the fence for height and length, 2 years ago I watched the SS video on there plan. I will do that, but what material, 3/4" Baltic Birch Polyied to seal it, or as most use for jig Mable the same? My provider of BB is flat not a Big Box stuff?
Re: Knowlegde needed!!
I say use whatever you have that is flat and straight that is likely to stay that way.
- BuckeyeDennis
Agree with JPG. I used a leftover cutoff of white melamine-covered particle board shelving from HD. Works great. And with the addition of a couple of SS T-nuts, it doubles as a tall auxiliary fence for my 520.
- thunderbirdbat
Add a couple of places to mount feather boards to increase the versatility.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
ERLover
Thanks all, I will have some left over 1/2" BB but not thick enough to counter bore/sink mounting bolts to the SS jointer fence, I will pick up some 3/4 sure cant wait to get the ER on the floor set up for a drill press at moms, need to make the bench for it, next project, still fine tuning other machines stuff here, a progressive order!!!
Life sucks setting up a new shop, floor plan and electrical, I hate cords on the floor, and plugging in and un plugging.
Got enough 1/2" BB to glue up to 1"?ERLover wrote:Thanks all, I will have some left over 1/2" BB but not thick enough to counter bore/sink mounting bolts to the SS jointer fence, I will pick up some 3/4 sure cant wait to get the ER on the floor set up for a drill press at moms, need to make the bench for it, next project, still fine tuning other machines stuff here, a progressive order!!!
ERLover
Thanks JPG, Da, never thought to do that
I might/should after the drawer is made.
ERLover
Just did my cut list for the drawer, I will have more then enough BB to double up to 1" for a 30" long X 5-6" high fence piece. When you have not chips and dust much over the last 6 months, the brain gets a bit stale, when it comes to thinking.
Ain't like you have nothing else to fill your noggin!
- robinson46176
I've reached the point that I no longer remember if I used to be smarter than this or not...
