Mark VII bag box 'bottom'
Continuing bag box 'enhancements' to the Mark VII
Repeating a previous post, the 'bottom' has a 'nest' that fits between the Mark VII 'legs'(they run horizontally end to end). The bag box sets in the middle.
Into this nest goes the shaper fence and the lathe tool rest parts.
fenc and tool rest.jpg (680.66 KiB) Viewed 1869 times
ADDITIONS TO LEFT END
ADDITIONS TO LEFT END.jpg (1.19 MiB) Viewed 1869 times
An end plate, a depression for the rip fence rear clamp and a nest for the miter gauge base end. Also 6 holes for mounting the bag box to the 'legs'.
ADDITIONS TO RIGHT END
ADDITIONS TO RIGHT END.jpg (1.61 MiB) Viewed 1869 times
6 more bag box mounting holes, another end plate, a nest for the rip fence base, and a peg for the miter gauge.
SLIDING PARTITION OPEN/INSERT
SLIDING PARTITION.jpg (656.68 KiB) Viewed 1869 times
The right end slides under the bag box right end(it extends a half inch in past the inner mounting holes). The left end of the sliding partition will clear the box box left end. The 'knob' serves as both a handle for moving the partition and a peg to mount the tail stock onto.
SLIDING PARTITION CLOSED
SLIDING PARTITION CLOSED.jpg (977.42 KiB) Viewed 1869 times
The partition slides to the left under the bag box left end. The right end remains under the bag box right end.
ADDING MORE STUFF TO THE LEFT END
MORE LEFT END STUFF.jpg (656.39 KiB) Viewed 1869 times
This addition is secured by the inner two bag box mounting screws at each end.
ADDING MORE STUFF TO THE RIGHT END
MORE RIGHT END STUFF.jpg (585.7 KiB) Viewed 1869 times
This is also secured by the inner two bag box mounting screws.
More follows - it gets 'populated'.
Re: Mark VII bag box 'bottom'
Now to show 'in situ'.
MITER GAUGE SEATED
MITER GAUGE SEATED.jpg (1.16 MiB) Viewed 1859 times
RIP FENCE SEATED
RIP FENCE SEATED.jpg (1.54 MiB) Viewed 1859 times
TAIL STOCK SEATED
TAIL STOCK SEATED.jpg (1.86 MiB) Viewed 1859 times
RIGHT END STUFF SEATED
RIGHT END STUFF SEATED.jpg (676.63 KiB) Viewed 1859 times
Two 10" sanding disks and a front table extension
LEFT END STUFF SEATED
LEFT END STUFF SEATED.jpg (535.26 KiB) Viewed 1859 times
Another sanding disk and a 10" combo saw blade
FINALLY EVERYTHING IN IT'S PLACE
ALL SITTING.jpg (1.4 MiB) Viewed 1859 times
Ignore the crap in the background :)
algale
Post by algale »
Looking good! Boy, those double sided conical discs are cool! 2 grits at once!
They are flat on the 'out' side and 'conical' on the shaft side.
The conical angle is less than the Mark 5/V/7. I have not measured it (yet).
Now just need to obtain some 10" abrasive disks.
The 'nest' for the disks may need to be altered. I made them sloppy to accommodate the added thickness due to the paper.
I may make the right side 'addition' over. I like the left side(made last) better.
Not really satisfied with the front table extension storage. Likely will fall when MVII is moved.
Thanks!
