Can someone Help
Can someone Help
Unless I am going completely senile, I am at a loss. I am sure I posted a reply with pictures of a modified SS 510 table with a Lexan insert with a Bosch router and IPM-fence set up on this forum. it seems to have disappeared since I have searched in vain for such a post. I have no idea when it was but it has been quite some time. Can someone point me in the right direction. The reason I would like to recover the post is that the photos that were attached have also eluded my search.
Don G
Don G
Re: Can someone Help
When I cannot find something I previously posted, it 'Almost always' turns out I 'previewed' it but never 'submitted' it.
I have recently prepared many posts that never made it to the forum. At first, I thought I was being censored. It turns out that all that is happening is I prepare it and then fail to submit it. Usually I will have done a "preview" before posting and then never submitted.
I blame it on distractions while I am posting but it might not be that easy to explain away.
I think this is post you are looking for http://www.shopsmith.com/ss_forum/viewt ... 41#p163441dgreen810 wrote:Unless I am going completely senile, I am at a loss. I am sure I posted a reply with pictures of a modified SS 510 table with a Lexan insert with a Bosch router and IPM-fence set up on this forum. it seems to have disappeared since I have searched in vain for such a post. I have no idea when it was but it has been quite some time. Can someone point me in the right direction. The reason I would like to recover the post is that the photos that were attached have also eluded my search.
Don G
rpd
Thanks a bunch!! I looked at every post except this one mainly because it was so long. How in the world did you find it?
Don G
Don G
Consider attaching an appropriate "title" to your posts. If you do that, it might help with a search.
I would never have thought to search for PowerPro Upgrade when looking for a Router Table modification.
In the Search screen I putdgreen810 wrote:rpd
Don G
Search for keywords: Bosch router
Search for author: dgreen810
That gave four results including the start of this thread.
If you want to search for posts that you have made the easiest way is :
Somewhere near the top of the screen there is a link that says Your posts .
Click on that and it brings up a screen listing all the posts you have made.
Near the top is a field that says Search these results:
Put terms in that field to refine you search.
My thought exactly, how in the *&^% did he find that??
Don G
Don G
BTW What you did to the table and router plate is quite ingenious. I have long wondered why Shopsmith has not done something like this.dgreen810 wrote:Dusty
Don G
PS
Also in the search results click on [Jump to post] and not on the Topic
That will take you to your post and not to the start of the thread.
