Shopsmith Table Storage System
jjbuzard
Post by jjbuzard »
I ordered the Shopsmith Table Storage System because I wanted an easy way to store the tables, etc. when not in use, I did so on faith, because there isn't a lot of pictures and information on how to use the system. After it arrived I thought that is a lot of money for what you get, but I figured as it is American made, I am willing to pay a little more. Even so it is a bit over priced. My original plan was to use the one last un-used space, the inside of the garage door. Here are the modifications and set up, it works great. To attach the system to the door, I used heavy duty perforated strap, screwed to the door frame.
The flippers to retain the tube automatically swing down into position if you forget to turn them over the tubes, as soon as the door starts up, their own weight swings them into place
Drilling Bracket for retainer flipper
Modif Brkt.jpg (868.71 KiB) Viewed 5740 times
Drilling Flipper to retain the tube holding the tables.
Brackets to hold extra tubes.
tube retrainers.jpg (548.01 KiB) Viewed 5740 times
Bracket installed
Bracket installed
The flipper is out of the way in this picture to allow the tube to be removed.
out of thge way.jpg (660.18 KiB) Viewed 5740 times
I had to add spacers so that the Tube Retainers would clear the door as it opens.
Completed, attached and ready for use. Dead space utilized.
installed complete.jpg (905.85 KiB) Viewed 5740 times
With the door open I can walk under the tables hanging from the Bracket
door open.jpg (1.15 MiB) Viewed 5740 times
ERLover
Re: Shopsmith Table Storage System
Post by ERLover »
JJ, Very nice and clever. To walk under that, it has to be one high door or one short JJ :)
jjbuzard
Post by jjbuzard »
ERLover wrote:JJ, Very nice and clever. To walk under that, it has to be one high door or one short JJ :)
It is a high door, if it had been a standard door I would have gone up one panel.
ERLover
Post by ERLover »
How would that have helped, Unless over something you cant walk?
Curly
Post by Curly »
That's very clever Mr. JJ
I ain't no physikist, but I knows what matters.
-Popeye the Sailor
ChrisNeilan
Post by ChrisNeilan »
uh huh? ER, I believe you may have a point there!
Chris Neilan
jjbuzard
Post by jjbuzard »
Right.But as it is, it goes up over where my Shopsmith sits, so it really doesn't matter and hangs directly where it sits and if it goes up, it usually comes right back down as the shop is heated and air conditioned.So it just making that dead "wall space"
useful.
ERLover
Post by ERLover »
jjbuzard wrote:Right.But as it is, it goes up over where my Shopsmith sits, so it really doesn't matter and hangs directly where it sits and if it goes up, it usually comes right back down as the shop is heated and air conditioned.So it just making that dead "wall space"
useful.
Got it.
Nice to have a heated shop. Even nicer to have it ACed!!!!!! :D
jjbuzard
Post by jjbuzard »
useful.
Got it.
Yeah as I get older I can't take the heat and I like to work in my shop all year round.
ERLover
Post by ERLover »
jjbuzard wrote:
useful.
Got it.
I feel ya, on the heat.
