DC3300 - More Specific Dimensions Needed
I will likely be buying a used DC3300 next weekend in a town about 100 miles away. I need something for my garage shop that pulls less power and is smaller and more portable than my big HF DC in my backyard shop.
I'm trying to figure out the height to see if it will fit in the back of my Forester, rather than taking my trailer, or if I'd need to do some disassembly (and if so, how much) to the DC3300 or remove my dog divider in the car (not quick, but not all that hard). I have about 42" between wheel wells, plus a little more at the very back behind the wheel wells, to possibly put it crosswise. I know Shopsmith says the height is 48", but doesn't say to where; is that to the top of the handle, the top of the included bag inflated, the top of the upper bag rim, something else? Could someone please measure the height to the top of the upper housing and the top of the handle?
Roy
Home designed and built CNC router, another CNC router
desktop size, Avid 5x10 Pro CNC w/ATC, CNCed G0704 milling machine
Laser engraver
Way too much other stuff and not enough space
Laser engraver
Re: DC3300 - More Specific Dimensions Needed
To the top of the handle is 41 1/2". But, to the top of the fan housing is 45".
Thanks! That's totally backwards from how it appears from the shopsmith.com photos and manuals.Lodgepole wrote:To the top of the handle is 41 1/2". But, to the top of the fan housing is 45".
Roy
Laser engraver
Laser engraver
br549
Congratulations on your upcoming acquisition! Hope these help. Also, in plan, "footprint" is about 26" x 21", if case vertical clearance is an issue when lying on its back or side.
- To top of handle
- P1161292.JPG (186.93 KiB) Viewed 5649 times
- To top of housing
- P1161295.JPG (230.32 KiB) Viewed 5649 times
br549
The assembly (or dis-assembly) instructions are also available as a pdf on Shopsmith's website, to help you know what tools to take and how it comes apart.
http://www.shopsmith.com/ownersite/prod ... Manual.pdf
br549 wrote:Congratulations on your upcoming acquisition! Hope these help. Also, in plan, "footprint" is about 26" x 21", if case vertical clearance is an issue when lying on its back or side.
Thanks for the photos. Guess it will probably be easier to take the dog fence off in advance than disassembling the DC (in possible rainy and/or cold conditions) and then I won't have any problems. The fence bottom is too low to fit the 21".br549 wrote:The assembly (or dis-assembly) instructions are also available as a pdf on Shopsmith's website, to help you know what tools to take and how it comes apart.
Roy
Laser engraver
Laser engraver
FWIW, I took one for a long ride in the front passenger seat(tilted full backwards) of an 86 honda accord. Even the seat belt operated correctly.
That big foot was my major concern.
My only source of dimensions was the ss web site. Since the 'ride' was over 200 mi(one way), I was relieved when it 'slipped' in as planned.
IIWM, I would pick it up in an 'empty' vehicle.
Hmm, I wonder if you put a wig on it if it would pass for a passenger for those cities that have HOV lanes?JPG wrote:FWIW, I took one for a long ride in the front passenger seat(tilted full backwards) of an 86 honda accord. Even the seat belt operated correctly.
Yeah, the back seat will empty, probably the whole car other than me.
Roy
Laser engraver
Laser engraver
Which out for sawdust in the DC3300.
Beeg, can you send me a private message or email, ffd95@att.net? I'm just across the river from you in Belleville, and have a bunch of questions.
Thanks
Thanks
