10ER Quill Spring
10ER Quill Spring
Is the 10ER quill spring the same as the MK V quill spring? They certainly look the same but are the dimensions the same?
- rjent
Re: 10ER Quill Spring
This question has been brought up before. I think the consensus was that they are (or at least close enough to interchange from the Mark V to the 10ER.
Why?
Why?
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
ERLover
Wow John, something you did not know about them ERs.jsburger wrote:Is the 10ER quill spring the same as the MK V quill spring? They certainly look the same but are the dimensions the same?
Because 10ER springs are sometimes broken. Yes you can fix the key hole slot ( I have done that) but sometimes there are other issues.rjent wrote:This question has been brought up before. I think the consensus was that they are (or at least close enough to interchange from the Mark V to the 10ER.
Why?
They are occasionally available on eBay from simon*e (Simon Eng?). I have bought one from him and it was fine.
You can only buy the spring from SS with the housing. It is about twice the price of Simon's but if you really need one it is a source that will be around hopely for a long time.
