Chisel Sharpening Jig ?
db5
Post by db5 »
I no longer can sharpen by sight nor feel as I'm just shy of being an octogenarian. Does anyone have a sharpening jig you've built that you would share?
RobertTaylor
Re: Chisel Sharpening Jig ?
Post by RobertTaylor »
I use the Wolverine system by One way, for my lathe tools. You did not say if for lathe tools or bench chisels. Bob
robinson46176
Post by robinson46176 »
I have other sharpening rigs but I thought that this one looked simple and effective when I saw it a couple of days ago.
Chisel sharpening jig.jpg (11.56 KiB) Viewed 3867 times
db5
Post by db5 »
What I'm looking for is a home-made jig for sharpening chisels on whetstones so that the angle will be correct.
roy_okc
Post by roy_okc »
Before switching to a Worksharp, I was using an inexpensive honing guide, such as the one for $9.99 here: https://www.woodcraft.com/search?utf8=% ... ton=search. It worked well enough, I made a couple length gauges from scrap wood so I could replicate angles easily. I would've bought the Veritas Mk II, but they weren't available at that time (some sort of longish term supply or contract issue, maybe?).
Here's one homemade guide, although the parts, if you had to buy, might be close to the same as a cheap pre-made:
http://www.instructables.com/id/DIY-sha ... ane-irons/
Roy
Laser engraver
davebodner
Post by davebodner »
Whenever I'm diligent enough to use this, I'm pleasantly surprised. Bonus: Made in USA!
http://www.acehardware.com/product/inde ... 004919bdaf
robinson46176
