Dust Collector
Dust Collector
Need help on how to remove the housing of the DC to see why I have play in the fan. I can move it back and forth, and it makes rubbing noise.Was only using for dust control when started making noise, no hose was attatched
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
woodmeister
Re: Dust Collector
I had the same problem as I could not get it out of that area even with clamp off. Mine would suck but not enough to blow up the larger cloth hood. Any suggestions? From what I could see the fan blade is not damaged.
Tom
Tom
kschwarz20
Re: Dust Collector
I just took my DC3300 apart last weekend to replace all the seals. It's probably not just tight; there are two hard to spot screws you may have missed. Look behind and below the motor box (in your photo) between the "fins" on the outside of the machine underneath the motor vent area. There are two screws there holding in the unit. Take them out (and disconnect the power connector in the same area) and you should be able to lift the whole assembly out with minimum effort.
br549
Re: Dust Collector
kschwarz20 beat me to it. Here's a picture if that helps any. The plastic bag is hiding the one to the right.
- 2 screws at back of DC3300.jpg (251.82 KiB) Viewed 5093 times
Re: Dust Collector
Got it, thanks to both of you.
Joe
Re: Dust Collector
Bolt broke holding fan on shaft. Off to Lowes to a easy out.
Joe
woodmeister
Re: Dust Collector
Thanks will look for them hidden screws!!
woodmeister
Re: Dust Collector
