I don't need no stinking CNC machine!
mbcabinetmaker
Post by mbcabinetmaker »
Even if I could afford it I cannot spare the room! ;)
2 (1).jpg (321.62 KiB) Viewed 9652 times
2 (2).jpg (362.12 KiB) Viewed 9652 times
This is a couple of display cabinets. The uppers will sit on the bases which are stacked one on top of the other on the left. Sorry I didn't have anyone around to help sit them up for a proper photo op.
Mark
2017 Power Pro Mark 7
Hobbyman2
Re: I don't need no stinking CNC machine!
Post by Hobbyman2 »
LIKE!!
As usual, Mark. This is just another example of the fine craftsmanship that comes from your shop. It is also another example of some of the unbelievable things that can be done without the new, modern, high tech equipment.
joedw00
Post by joedw00 »
Looking good as usual.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
I like the design and that fact that you were able to produce it with your trammel, nice piece of equipment btw. Maybe after I get all my green tools I might bite for one of those....
Will or is there glass for support? Those pieces being as thin as they are must have some sort of support I would think????????
mbcabinetmaker
reible wrote:I like the design and that fact that you were able to produce it with your trammel, nice piece of equipment btw. Maybe after I get all my green tools I might bite for one of those....
http://www.microfence.com/ Great equipment and great service.
Yes they will have 1/8" tempered glass.
Mark
Dccarpenter
Post by Dccarpenter »
Awesome work, I have some similar looking window sash to fabricate so had a few questions.
Did you cut that out of glued up solid stock ?
Also, when installing the glass are you using 3m tape to keep the mullion flat on the glass, a silicone of some sort, or just clips at the edges?
mbcabinetmaker
Dccarpenter wrote:Awesome work, I have some similar looking window sash to fabricate so had a few questions.
The grids are made from alder veneer on 1/4" MDF. It is pretty flat so no silicone should be needed. The glass will be held in with wooden strips attached to the back of the door with small countersunk screws.
Mark
