Homemade Lathe sharpening jig
heathicus
Post by heathicus »
Since I've been doing more turning, I've been struggling to keep my lathe tools sharp. I just can't afford the Wolverine jig. I tried the Shopsmith lathe sharpening guide, but could never quite get it right. I tried freehanding based on some videos I watched, but couldn't master that either. I stumbled upon a YouTube video showing someone's shop made jig like the Wolverine and the light bulb lit up. Why didn't I think of that before?
I had rescued two good pieces of 3/4" plywood out of the scrap pile at work the day before and used them for this. No real plans, just making it up and figuring it out as I went along. And it works great! My lathe tools have never had such a great cutting edge!
I still need to make the skew attachment.
Heath
Central Louisiana
rcplaneguy
Re: Homemade Lathe sharpening jig
Post by rcplaneguy »
Nice! Where did you find the red plastic varigrind-type jig?
masonsailor2
Post by masonsailor2 »
Nicely done. Having that really good edge on the tools makes turning a lot more fun.
Paul
heathicus
Post by heathicus »
rcplaneguy wrote:Nice! Where did you find the red plastic varigrind-type jig?
I printed it with my 3D printer!
Heath
Central Louisiana
roy_okc
Post by roy_okc »
Heath,
Awesome platform. Are you holding the extension arm in place from underneath?
Did you design the "vari-grind" jig yourself or find? If found, would you mind sharing the link? My 3D printer isn't doing anything at the moment ;^)
Roy
Laser engraver
rpd
Post by rpd »
Heath. a bit off topic but, now that you are getting into turning, a set of these makes adjusting the tool rest a lot easier. :)
https://www.mkctools.com/10ertoolresthandles.htm
heathicus
Post by heathicus »
roy_okc wrote:Heath,
Right now, the arm is tight enough in the slot that I don't need anything else to hold it in place, but not so tight that I can't adjust it with a little nudging. As it loosens up through use, I'll add a bolt and knob on the top to clamp the bar down.
Here's the link to the 3D printable Vari-Grind. https://www.thingiverse.com/thing:1855586
Heath
Central Louisiana
heathicus
Post by heathicus »
rpd wrote:Heath. a bit off topic but, now that you are getting into turning, a set of these makes adjusting the tool rest a lot easier. :)
I sent that link to my wife yesterday as a suggested Christmas present!
Heath
Central Louisiana
roy_okc
Post by roy_okc »
heathicus wrote:Right now, the arm is tight enough in the slot that I don't need anything else to hold it in place, but not so tight that I can't adjust it with a little nudging. As it loosens up through use, I'll add a bolt and knob on the top to clamp the bar down.
Thanks Heath, going to fire up the ol' printer shortly and see how it comes out.
Roy
Laser engraver
Locoloboblu
Post by Locoloboblu »
Looks like a good idea. I hope to put it to use soon.
I have a problem with my Shopsmith. I bought it from some guy through a "For Sale" notice in the want ads of the local paper. He told me it was a 1953 Model, but now, thanks to technology, I see that is not correct. I have the same machine that is in the picture (20171202_211131.jpg) in this post. Can you tell me what model it is, where I can find an owners manual and where I can get replacement parts? My speed adustment bracket is broken.
