wiring motor to 4 post toggle switch
While disassembling the headstock of my Shopsmith, I inadvertently removed the screws mounting the motor to the pan. This allowed the motor to slide forward & pull the wires from the pins & I have no idea as to which pins they were connected. I have a 1980 Mark V with a Smith motor which has 4 wires ( black, white, green, yellow ) . The switch has two posts on each side of the top & two posts on the bottom. Any help would be greatly appreciated.
Re: wiring motor to 4 post toggle switch
4 wires that are connected INTERNALLY to the motor?
I would expect 2: one white, one blue.
Look closer at the green and yellow wires and where the ends are.
The 4 wires are connected INTERNALLY to the motor,& there is no blue wire.The yellow wire could be considered beige, as the wires are 38 years old. I also failed to mention the top 2 pins on the toggle switch are the ON & the bottom 2 pins are OFF. My problem is knowing which colored wires go to which pins.
Thank You!
Thank You!
Where are you located? Not USA? Is the motor dual voltage? Can you post a pix of the motor name plate?
Do you have an Ohmmeter?
br549
All of JPG's questions are good ones, and I hope you will answer them, as he is much more of an expert on anything electrical than I will ever be.
A while back there was a similar question and post about wiring a switch, and I either copied or created this picture, which summarizes the Sawdust Session SS103 for replacing a switch. It took me while to find the actual Sawdust Session (had to Google it to find it), as I couldn't seem to access it directly from the Shopsmith site.
http://www.shopsmithacademy.com/SS_Arch ... Switch.htm
While the video shows the process of replacing a switch, the 3 diagrams were shown on the "blackboard".
And again, thanks to anyone else who may have created the picture, if I copied and saved your work for future reference.
- Shopsmith Switch Wiring.png (1.19 MiB) Viewed 8006 times
I find it necessary to APOLOGIZE for my mistake in saying all 4 wires were connected INTERNALLY. At my age, my mind isn't as sharp as it was years ago. After your last response,asking for the motor name plate, I removed the motor to take a photo. When removing the motor, I discovered there were only 2 wires (green & yellow ) coming from the motor & 2 wires ( black & white ) from the line cord. If you still need a photo of the name plate, I need to find out how to transfer photo from the camera too the message board. I believe the motor is 110v only & do have an ohmmeter. My residents is in Davison Michigan.
THANK YOU!
THANK YOU!
