Why? Because I am cheap... uuhhh, frugal maybe? Yeah, let's go with that...
1"o.d. 3/4 i.d. , 3/4 o.d. 5/8 i.d., 5/8 rod... All items are 304L SS...
Cut them all on the bandsaw to length, then I cut slots/edges of the soon to be spur. Next, I went over to the belt sander and began the shaping up of the spur.
Next, I grabbed the solid rod and began shaping it on the belt sander also. Dipping it frequently in water.
Then I welded it together. Finally, I drilled and tapped the hole. All in all about a 30 minute DIY.
DIY Lathe Spur...
DIY Lathe Spur...
- Different view
- 2018-07-07 20.25.05.jpg (347.33 KiB) Viewed 5797 times
- Everything stacked together
- 2018-07-07 20.33.08.jpg (519.48 KiB) Viewed 5797 times
- Bandsaw notches for edges of spur
- 2018-07-07 20.33.27.jpg (277.32 KiB) Viewed 5797 times
- Rough outline of what to remove
- 2018-07-07 20.37.56.jpg (436.83 KiB) Viewed 5797 times
- Rough shape, but its getting there...
- 2018-07-07 20.40.33.jpg (241.23 KiB) Viewed 5797 times
- Cleaned it up some and drilled and tapped the hole...
- 2018-07-07 20.46.39.jpg (347.58 KiB) Viewed 5797 times
- View from the top...
- 2018-07-07 20.49.03.jpg (290.27 KiB) Viewed 5797 times
- And finally, it actually in a piece of wood...
- 2018-07-07 20.49.31.jpg (372.94 KiB) Viewed 5797 times
Re: DIY Lathe Spur...
Very nice. That is one mean looking spur.
Thank you! Looking "mean" wasn't my goal, but I knew that it had to hold, on anything and everything I threw at it.
