E4 Jointer V-Belt Size
csxeng
Post by csxeng »
Does anyone know what size belt is used for the E4 jointer or replacement part number is? I uploaded this picture with circle for reference. Thanks in advance.
Dave V.
Re: E4 Jointer V-Belt Size
The belt is a 4L 320 or 32" belt. The pulley on the jointer is 1-3/4" and the motor is 5". The Jointer Mounting Kit Instructions are in the PDF below. Sorry the only 4E Jointer Manual I have is a not-so-good photo copy.
Jointer Mounting Kit 05-53.pdf
(539.68 KiB) Downloaded 1066 times
A Model 620 manual would also work for this Jointer. The early 620 is the same except for the Base (outfeed Table) which has the tube mounting holes and the two tubes for SPT mounting on the Mark 5. If anyone has a good original 4E Jointer Manual it would be nice to get a PDF copy of it available here.
chapmanruss wrote:The belt is a 4L 320 or 32" belt. The pulley on the jointer is 1-3/4" and the motor is 5". The Jointer Mounting Kit Instructions are in the PDF below. Sorry the only 4E Jointer Manual I have is a not-so-good photo copy.
Here is the PDF that I have. It is pretty good.
4ejointer.pdf
(1.01 MiB) Downloaded 1201 times
csxeng
Post by csxeng »
Thank you John and Russ for your help! Surprisingly, the person that I have purchased this Jointer from had the original owners guide mounting kit instructions in fantastic condition. I just needed the belt size. Russ, Did you need a good scaned copy of the owners guide and mounting instructions?? I can scan a good copy for you!
Dave V.
Dave,
I just downloaded a copy of John's PDF Manual, Thanks for posting that John. His copy is a good one so unless your's is better than it, I am happy with John's copy. Thanks for the offer. Having these available here may help others who do not have a copy.
