I traded my motorcycle for a 520. The gentleman that owned it before built cabinets. The system didn’t come with a band saw, 4 inch jointer or 6 inch sander however I have picked those up.
The system did, however, include two power stands that I want to mount the band saw and jointer on. The stands have the belt drive pulleys but I need the pulley attachment that goes on the band saw and jointer.
I know that Shopsmith does not manufacture the stands anymore.
Where can I get these Pulleys.
Pully for band saw and jointer
Re: Pully for band saw and jointer
Back in the day when we all had 'hardware' stores, I would have suggested them.Jolson wrote:I traded my motorcycle for a 520. The gentleman that owned it before built cabinets. The system didn’t come with a band saw, 4 inch jointer or 6 inch sander however I have picked those up.
Now days a bit of searching may be required. Industrial suppliers such as Grainger, MSC ... come to mind.
- BuckeyeDennis
My local ACE hardware carries pulleys of that type. If you can't find them locally, you can definitely order them from McMaster Carr. Probably Amazon as well, but it will be harder locate the products on the Amazon site.
I've attached a PDF of an instruction sheet that gives the recommended power-stand pulley sizes for your SPT's (Special Purpose Tools).
- everettdavis
To go McMaster-Carr website and search for v-belt pulley
You can likely find the sizes you want.
Everett
Everett
Jolson
I don't know if you live in a rural or urban area but if you are rural or suburban, stores like Tractor Supply or Rural King will have a substantial selection of pulleys.
