Shaper Fence
bakirkland
Shaper Fence
Post by bakirkland »
I am missing the hold down bolts for my over table shaper fence. I don't seem to see the fence in the service parts section. Any help would be appreciated.
Re: Shaper Fence
The bolts are 3/8" -16x 1 3/4 socket head cap screw. There is a flat washer and the 3/8" x 16 square nut.
454475 - the cap screw
120394 - flat washer
515110 - 3/8 - 16 nut
This data is applicable to the 510 shaper fence. Hope you don't have a 500. :)
Re: Shaper Fence
If you need the parts Dusty listed for the 510/520 Shaper Fence they are common hardware parts and should be able to be found locally and cheaper.
If you need the parts for the 500 Shaper Fence they are
Clamp P/N 5130789 $13.64 (not sure if this is each or a pair so a call to Shopsmith would needed)
Clamp Screw P/N 426370 $3.95 each
Washer P/N 120394 $3.95 each
The Clamp screw is an Allen Wrench Cap Screw and a plain washer. I recommend getting the Clamps and buying the washers and cap screws locally. Shopsmith's minimum price for parts is $3.95 to help cover their costs of getting, stocking and handling of parts.
Sorry I do not know the size of the washer and cap screw but if needed I can get it. My 500 Shaper fence is stored. I believe they are 3/8"-16 since the washers are the same for the 500 and 510/520.
bakirkland
Re: Shaper Fence
Thanks guys, if is a 510 fence and this is exactly what I needed
