Are these Shopsmith accessories?
I have a few items that came with a 10er I bought. I can't find them in any of the paperwork I have. I'm hoping someone can tell me if they are Shopsmith accessories or some other brand.
- Lamp
- Shopsmith lamp.jpg (151.2 KiB) Viewed 9797 times
- Clamp
- Clamp.jpg (120.87 KiB) Viewed 9797 times
- Coupling
- Coupling.jpg (206.86 KiB) Viewed 9797 times
- Coupling close up
- Coupling close up.jpg (104.53 KiB) Viewed 9797 times
Re: Are these Shopsmith accessories?
The lamp is not Shopsmith. You can see a SS lamp in the attached picture.donpol wrote:I have a few items that came with a 10er I bought. I can't find them in any of the paperwork I have. I'm hoping someone can tell me if they are Shopsmith accessories or some other brand.
The second picture I believe is a clamp from the Magna set of stock hold downs. Someone will correct me if I am wrong.
The third picture is the flexible coupler used to connect the A-34 jig saw to the 10ER spindle.
- IMAG0070.jpg (209.64 KiB) Viewed 9788 times
John is totally correct on the first two. The clamp is shown below.
The Third item is not a Shopsmith/Magna part but if it is the correct size is a substitute for the coupler to connect the Jig Saw to the Model 10's spindle.Russ
All SPT's & 2 Power Stations
chapmanruss wrote:John is totally correct on the first two. The clamp is shown below.
That is what I thought but forgot to mention it. Lovejoy makes couplers today that will work.
donpol,
I should have been clearer before. From the other pictures I see one end has a sleeve in it. To work as a replacement for the coupler for the Jig Saw on a Model 10 it needs to have a 5/8" bore on both ends. The original coupler is 1-7/8" long and 1-3/16" diameter. Sorry I did not give you these dimensions before. If a replacement is too long, to large in diameter or has the wrong size bore it will not work.
The Lovejoy coupling works. I got one "just in case" the original fails for my son.
Info from sale receipt:
2 required: L070x .625 1024 These have a keyway but not really needed.
Bore 5/8 hub od 1.36 max rpm 3600.
1 required: L070 10406 spider solid center
Since there are 3 pieces I put clear duck tape around them (so son won't loose them
Test fitted and ran, didn't see any problems
Cost was less then 20.
Bob,
He was just trying to identify the parts and not looking for other options. I posted the clarification based on the pictures in his eBay ad.
