Upper Blade Guard / Miter Gauge Issues// FIXED
Thomschuck
Post by Thomschuck »
Fellow Forum,
I wanted to post how two problems were resolved with Forum help.
Upper Saw Guard Play.
I had a lot of excess play in the clear plastic upper blade guard. I nulled out 80% by installing extra washers and shims at the rear pivot pin. Where plastic meets metal. Be sure that when using shims and such to put equal numbers on both sides of the pin. The small clips went on nice and tight. That was a huge help. It sits equal over my blade. When evaluating the mount I discovered the knob was missing. It had a bolt of unknown origin twisted into it. After I cleaned that up I installed a knob I had. It went tight quick. Riving knife is spot on. Way Better, much safer.
Can anyone confirm the threads on that knob? I used a 1/4 20 thread knob. It went in weird tight?
Miter Gauge
My miter gauge had the nylon set screws for glides. ShopSmith no longer sells the set screws. They do sell the newer nylon cap head screw. I replaced the glides with nylon screws that I cut the heads off. I filed it clean then used a hacksaw to strike a deep grove for a flat blade screwdriver. Worked out well...There was also a problem with the miter gauge when pushing it thru the slot. After this and that I discovered that the miter bar was bent. Just like a ski. discovered by chance when I placed a machined straight edge on the bar. That bend caused the miter gauge to teeter increasing drag then sliding free. If you have glide issues, you might check your miter bar with a machined straight edge.
YOHO! Thanks for the options & help. Very Cool.
Thom Schuck
Portland, Oregon
Thom Schuck
SS Model 5 500 Completely Restored
SS Bandsaw Completely Restored
SS Jointer Completly Restored
SS Biscuit Cutter
Rikon Low Speed Grinder W/Wolverine jig
Kreg Tool TrackHorse X 2 + Kreg Tool Project Center with 35 Kreg Tool Clamps
11 Systematic Blades of every configuration
Bosch/Mikita handheld power tools plus every hand tool in the book.
Ulmia Chisel sets X 3
Permobile Custom RideForward Powerchair
Complete set of registered # NASA X-15 Custom Tools W/Ownership certificate
Re: Upper Blade Guard / Miter Gauge Issues// FIXED
Try 1/4 - 28??? :)
Glad you have thing working again. How ever the knob is 1/4-28 so you might well have damaged the threads.......
Here are a couple of more pictures that might help to identify what might have been different then stock, ie modified for some reason??
upper guard.jpg (176.07 KiB) Viewed 8857 times
Thomschuck
Thanks for the heads up on 1/4 28. That was the trick! I cleaned up my threads and the new knob went right in. Clean and tight. Thank You for that.....
TS
Thom Schuck
SS Biscuit Cutter
