WD-40 (Brand) Specialist Rust Remover Soak
Haven't tried it yet or even seen it in stores but I do like their other products.
https://www.amazon.com/WD-40-Specialist ... way&sr=8-2
A bit more expensive but not so out of line that I will not try a gallon at some point.
Anyone try this yet?
Re: WD-40 (Brand) Specialist Rust Remover Soak
Sure does resemble Evaporust!
Over on youtube a chuck restoration included this product. Notable was that it appeared to NOT affect BLOX.
Wonder if that is correct!
everettdavis
Post by everettdavis »
James,
It does look like Evaporust! At $21.51 per gallon, delivered free with Amazon Prime, by Thursday... it's not too hard to find either, but neither is Evaporust...and it's only $16.85 per gallon, also delivered free with Amazon Prime, by Thursday...
Everett
WD 40 Rust Remover.png (251.57 KiB) Viewed 17437 times
So at some point, maybe in May I'll get a gallon of this stuff to see how it compares to other things I've used.
"Notable was that it appeared to NOT affect BLOX." if this is correct then I'll love it for a few things I have that I've left in original condition despite some light corrosion.
Wish I had some identical parts to test in both but can't think of anything at this time, that would be the best test. I think I have some Frog left too so it could be a three way test but then I would need 3 identical things....
Ed in Tampa
Post by Ed in Tampa »
Okay I give what is BLOX.? I guess Boiled Linseed Oil but I have no idea what the x is.
A google search did not provide an answer..
so you tell me what is BLOX please!
rpd
Post by rpd »
Ed in Tampa wrote:Okay I give what is BLOX.? I guess Boiled Linseed Oil but I have no idea what the x is.
BLack OXide (of iron) the surface treatment on arbors and such. As opposed to brown oxide (rust) :)
