Wolverine jig on Shopsmith
larryhrockisland
Post by larryhrockisland »
Got a Wolverine sharpening jig set up on my MarkV and got a CBN wheel. I will get a regular 8" wheel for rough grinding on the left side. I still need to come up with something to protect the waytubes. I clamp the wood bases so they don't slide and everything is solid. The left hand jig is notched deeper and will work on my 10ER also. I am still learning to use the Wolverine vary grind set up and I'm very happy with my infinitely variable speed grinder :D Thank you Shopsmith!
Cheers!
IMG_0288 (Custom).JPG (281.82 KiB) Viewed 19761 times
IMG_0289 (Custom).JPG (258.49 KiB) Viewed 19761 times
Deeper notch works on the 10ER
IMG_0290 (Custom).JPG (236.07 KiB) Viewed 19761 times
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
nuhobby
Re: Wolverine jig on Shopsmith
Post by nuhobby »
Tell us more about that mechanical + electric speed controller :)
I use a Power Pro with the strip sander for a lot of basic blade grinding. Yes, slow speed capability is a real boon to working without overheating.
Nice setup!
Chris
tenbears
Post by tenbears »
Which of the mandrels are you using for the CBN wheel
larryhrockisland
nuhobby wrote:Tell us more about that mechanical + electric speed controller :)
Nice setup!
Chris
Thanks
An electric speed controller would be nice but it is a digital tach I got from Skip at MKC Tools. Sorry no breakthrough invention here :D :D
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
larryhrockisland
tenbears wrote:Which of the mandrels are you using for the CBN wheel
The mandrel is the 505506 5/8" Molder/Dado Arbor
Larry Hargrove
Rock Island, Ok
1953 10ER
Another 10ER
I did this same sort of set up a few years back, the thread is here:
https://www.shopsmith.com/ss_forum/view ... ne#p205543
I had a few minor issues with this and finally went to a conventional grinder with the set up. Just a bit more convenient to have this way for me but it was an interesting experiment.
