Holding your liquor
masonsailor2
Holding your liquor
The next project is a redo on the liquor cabinet. It will be a combination of mahogany and alder. Part of it will be three large turnings out of mahogany in a tulip style to hold the platters which will be mounted on a vertical turnstile. The basic dimensions of the turnings are 15” diameter and 16” high. I am laminating them out of 8/4 African mahogany. The platters that will sit on top them will be alder. Today I started gluing up the first of the turnings.
Paul
Paul
- D1C3578A-AB35-492A-92AF-348C6F839CCC.jpeg (127.96 KiB) Viewed 26977 times
- F3BF8C79-599E-4896-B366-E212361581FC.jpeg (247.85 KiB) Viewed 26977 times
- 36E80C80-CFE9-4FCF-BF79-A631D503EBE4.jpeg (270.06 KiB) Viewed 26977 times
- 1CF3D8CB-2294-4F7E-B564-4E142C222774.jpeg (262.18 KiB) Viewed 26977 times
- 43A03660-F1DB-41E5-90A5-8C8DC37C6D13.jpeg (250.04 KiB) Viewed 26977 times
masonsailor2
Re: Holding your liquor
I glued up the rest of the first tulip blank. It’s very heavy so this is going to be slow going. I’m not going to use the traditional tailstock. I have a stripped down headstock which I will mount on the tubes facing the powered headstock. That way I can use a faceplate on each end for better stability.
Paul
Paul
- 24406190-1A8F-45DB-89D7-623E3D8113E8.jpeg (282.54 KiB) Viewed 26903 times
- BuckeyeDennis
Given that a Mark V has an 8-1/4” swing, and you’re planning on a 15” finished diameter, what’s your plan for rough-cutting that monster glue-up down to an OD that will fit on the lathe?
masonsailor2
I will cut it down on the bandsaw to about 15 1/2” diameter which will fit. The finished diameter will end up around 14 1/2”.
Paul
Paul
- BuckeyeDennis
Aha! I normally rough-cut bowl blanks round on the bandsaw, but I was thinking that the 16” height of the workpiece would be too much even for my 14” bandsaw with riser block. But now I see that you don’t have to get the top section of your glue-up underneath the top bandsaw guide. I’m guessing that you have something larger than the SS bandsaw as well, that can handle the height of the glue-up base.
masonsailor2
Yes I kept the outer level at 5” so either the SS or the grizzly will cut it easily
Paul
Paul
masonsailor2
After a lot of carving with the bandsaw and sawzall I got the blank mounted on the SS. The PP did not like the slow speed and 50lbs of wood but it got the job done. Once I was able to get the speed up to about 650 rpm the motor stopped making that annoying noise. It is roughed out and now I can do the final shaping. I have two more of these to make but hopefully I will be able to speed up the process.
Paul
Paul
- FD28FE44-9066-459F-A06F-4BEA9E6C6FF1.jpeg (258.66 KiB) Viewed 26768 times
- 54626C54-31F6-4D22-AAB5-F68DF02A5D42.jpeg (225.75 KiB) Viewed 26768 times
masonsailor2
Except for final sanding first one is done.
Paul
Paul
- AE142A4B-43DB-44B7-A858-2ED0EC9D9C24.jpeg (245.42 KiB) Viewed 26694 times
- E22BDD52-147E-4364-BD51-5C36CDE86B4B.jpeg (142.58 KiB) Viewed 26694 times
- EE0FC61D-A786-495E-9ED7-07F6EC42CBB1.jpeg (197.62 KiB) Viewed 26694 times
masonsailor2
The first tier turning is done. We tried to use the different colored mahoganies to get the overlapping petal effect and i think it worked pretty well. Now for the other two tiers.
Paul
Paul
- 1822CAA3-C985-4303-ADD7-87068853C3B4.jpeg (248.94 KiB) Viewed 26628 times
- 5E4EA9A3-8C2A-40B4-A6F5-FFB88CC22D65.jpeg (252.28 KiB) Viewed 26628 times
- BuckeyeDennis
Paul, that is going to be absolutely stunning. I just went back and re-read your first post, and I think I finally understand what you’re up to. I can’t wait to see some pics of it loaded up with fancy liquor bottles!
