Miter Gauge octagonal pads removal?
number3456
Post by number3456 »
I am doing some long over due maintenance on a SS purchase and was going to adjust the miter gauge octagonal pads to eliminate the gauge’a rocking on the main table. I removed the set screws to get to the slotted screw to adjust the octagon pads and the heads are so messed up the slot is completely gone. I am thinking that the only way I am going to get it out and replaced to drill it out and use a ease out.
I am hoping someone out there has a better suggest on how to remove the stripped screw.
520 now upgraded to Mark 7, 520 "shorty", 500 converted to a dedicated drill press.
2 - bandsaws, jig saw, belt sander, strip sander, 4" Jointer, planer, air compressor.
ClearVue dust collection system.
br549
Re: Miter Gauge octagonal pads removal?
Post by br549 »
If your glides are hexagonal shape (six sided, not eight), you must have the newer style. The slotted head for removal should be on the bottom. If you don't see a slot, then they are probably just worn down and need replacing. Here is a thread that shows and explains it better.
https://www.shopsmith.com/ss_forum/view ... es#p254433
number3456
Thanks that helps. I guess mine is the older style after all with the slotted screw. Since it’s nylon maybe I can dig it out somehow.
number3456 wrote:Thanks that helps. I guess mine is the older style after all with the slotted screw. Since it’s nylon maybe I can dig it out somehow.
Tap a small flat screw driver into the nylon stub. That should allow you to simple screw it out.
stew
Post by stew »
Heating the end of the screwdriver first might help with forming the slot
number3456
Got them out! This afternoon I called SS to check on a order I had in to SS since February and they don’t have replacement parts so I found some nylon bolts at FleetFarm that I can adapt for new pads.
Thanks all!
