Table insert for 555220 scroll saw
KentuckyEd
Post by KentuckyEd »
Does anyone 3D print a table insert for the 555220 scroll saw? If you're out there please let me know. Otherwise I'll be making some out of some birch plywood that I hope I still have.
Thanks in advance, Ed
Re: Table insert for 555220 scroll saw
If your Scroll Saw has the same table as the one shown in the picture below it uses the same table insert as the Bandsaw with the aluminum table. It is part number 516173 Bandsaw Table Insert for Aluminum Table.
_
Model 555220 ser 020293.jpg (110.26 KiB) Viewed 1147 times
_
There was an earlier Scroll Saw Table that uses a different insert. If your Scroll Saw table looks like the one in the picture below the insert is more like the Jig Saw insert. It was part number 515196 and is no longer available.
_
Scroll Saw Table from early Model 555220.jpg (122.88 KiB) Viewed 1147 times
_
For those interested the current Scroll Saw does not use a separate table insert.
KentuckyEd
My table is the first option. Thank you very much for the information.
Ash1562
Post by Ash1562 »
KentuckyEd wrote: Sat May 29, 2021 12:33 pm My table is the first option. Thank you very much for the information.
Hi Ed - did you end up making this?
1960's vintage Shopsmith Mark VII with Bandsaw, Belt Sander, Jointer
