Woodpeckers has finally taken on the miter gauge segment. This one is a bit unique in that it only does 90 degree cuts. Should it ever need adjusting, I like the eccentric adjustment design. I also like the 5 nylon leaf springs on the miter bar to attempt to compensate for miter slots that are too wide or too narrow. Still, I wonder if it will even fit in the smaller width Shopsmith miter slots. Of course, the extra long miter bar would probably make this miter gauge a non-starter on the smaller Shopsmith tables because it would be too unwieldy (IMHO). The miter bar is likely too thick for a Shopsmith miter slot as well. Still, a very nice miter gauge if you have a non Shopsmith table saw in your shop. I really like the Woodpeckers fence stops and graduated fence on this one.
https://www.woodpeck.com/exact-90-miter-gauge.html
Woodpeckers Exact-90 Miter Gauge
Re: Woodpeckers Exact-90 Miter Gauge
No doubt, this miter gauge, in keeping with Woodpeckers reputation, would be a nice addition to many table saws. However, I see no advantage that it provides over any other "accurate", adjustable miter gauge. For typical Woodpecker prices, I would expect something really, really unique.RFGuy wrote: Tue Jun 15, 2021 11:37 am Woodpeckers has finally taken on the miter gauge segment. This one is a bit unique in that it only does 90 degree cuts. Should it ever need adjusting, I like the eccentric adjustment design. I also like the 5 nylon leaf springs on the miter bar to attempt to compensate for miter slots that are too wide or too narrow. Still, I wonder if it will even fit in the smaller width Shopsmith miter slots. Of course, the extra long miter bar would probably make this miter gauge a non-starter on the smaller Shopsmith tables because it would be too unwieldy (IMHO). The miter bar is likely too thick for a Shopsmith miter slot as well. Still, a very nice miter gauge if you have a non Shopsmith table saw in your shop. I really like the Woodpeckers fence stops and graduated fence on this one.
Frankly, it looks to me as though Woodpecker is trying to copy some Incra tricks with minor changes (to avoid legal conflicts).
This came up in the YouTube comments, and I didn't have an answer...
What are the width and depth dimensions of the Shopsmith miter gauge slot? (In thousandths, if anyone can).
Jeff,JEFFinCLE wrote: Tue Jun 15, 2021 6:48 pm This came up in the YouTube comments, and I didn't have an answer...
I believe the consensus is that Shopsmith miter slots are 23/32" wide and 21/64" deep. Keep in mind there are multiple product versions over 70+ years so there is some variability in these miter slots from one customer to the next. I don't believe there is a published spec for it, so just going off of what I have read in the past on this forum. If I am wrong on these measurements then hopefully someone will correct me. Competitors in the marketplace are nominally 3/4" wide by 3/8" deep for comparison.
This sketch depicts what I believe to be typical of the Shopsmith Main Table miter tracks. It is not a specification. It is a recording of my measurements and nothing more.
- Miter Track, The Anatomy of a (decimal).jpg (56.83 KiB) Viewed 3897 times
- Miter Track, The Anatomy of a.jpg (56.63 KiB) Viewed 3897 times
I'll share this with the product engineer tomorrow and report back. Other than possibly being just a little too thick, I think it is going to work.
