Model 500 Saw Arbors
judaspre1982
Post by judaspre1982 »
a1gutterman
Post by a1gutterman »
judaspre1982 wrote:I am trying to find out if you can use SS model 500 saw arbors on a 510 table system. I have searched in the archives and read you can not because of saw guard alignment or something to that effect. Is there a way to adapt the 500 arbors? Are there any other reasons they will not work? Because of the economy I have an opportunity to get a 1995 MK V 510 very cheap but I have spent a large amount of money over the summer investing in my 1955 greenie. I am happy with my greenie but the price of the 510 is hard to beat. I just cant afford to start buying more 510 accessories. Are the saw arbors and table inserts the only items that would have to be added. Any input would help in my decision making. The guy said he has one saw arbor and one table insert. My future plans are to start using the SS equipment as a source of income for a small business venture so I am looking at this purchase as an investment.----Dave
ShopSmith says No. Others say it is possible, but there are problems. I have ever only owned a 510, so I can knot say, as I only have arbors meant for the 510. I do knot believe that any one on this forum recommends doing so. I think that I remember reading posts that say the blade will hit something or the arbor will hit something, or that you will knot be able to use the lower saw guard, or...?
Tim
Hi Dave,
Sorry but it is not safe to use the shorter 500 arbors on the 505/510/520 machines. If you have extra sanding disks and want to use them in the table they will also have to be upgraded...
If you are planning to keep both machines (not at all a bad idea) then budget some money for new parts for the 510 and retain the bits you have that work with the older one.
judaspre1982
My inexperience goes the other direction. I have never worked with a true 500 so I'll not comment.
However, if you have as good a deal as it sounds on the 510, I would snatch it up now. Arbors are not that expensive and you don't actually have to have more than one. All it takes is a couple minutes to change arbors when you have to. As times get better, arbor count can be increased and you are an all around winner.
GO BUY IT if you have room and a need.
http://www.shopsmith.com/ownersite/catalog/swd_sawbladearbors.htm
Twenty two dollars each - how many do you need to outfit all of the blades you intend to ever have. I have six and two of them have not been mounted in years. To follow my advice, you would have to buy 3 because you already have. For a $66 future investment I would not let that Mark V get out of my sight. Furthermore, with a bit of frugal shopping you can beat the $66 investment.
