Jointech items in photos
This post will contain a large number of pictures of Jointech pictures all collected in this one spot. They are all ones that at one time were on my Flickr site.
The first two post have what I like to call router insert details. The remaining posts will contain various other things so look for yourself... "it's a collection".
Only 18 views on these first 6 picture shown. Again they are in the Jointech information but this is also good for general knowledge so it wouldn't hurt to look at them.
Here is pictured a ring that is too large for say a 1/4" bit. You have several options to reduce the hole size.
[ATTACH]2850[/ATTACH]
This is one of the optional rings that shows the opening around the bit like you would like to have it.
[ATTACH]2851[/ATTACH]
This is a brass reducing ring, it is the same standard as the pc template guides but is flat and designed to reduce the opening around the bit.
[ATTACH]2852[/ATTACH]
This is the ring that lets you use template guide bushings. This is the standard called "pc" or "PC" that is used by Porter Cable
[ATTACH]2853[/ATTACH]
Keep reading on the next post below.
- jri1.jpg (107.45 KiB) Viewed 8820 times
- jri2.jpg (98.67 KiB) Viewed 8818 times
- jri3.jpg (108.13 KiB) Viewed 8827 times
- jri4.jpg (105.47 KiB) Viewed 8821 times
The jointech table showing where the mounting plate sits. Phenolic material
[ATTACH]2854[/ATTACH]
This is on the bottom of the plate and is used to snug the plate into the opening and keep it tight. It is called a "snugger". You can also see the bottom of one of the 8 set-screw used to level the plate in the table
[ATTACH]2855[/ATTACH]
- jri5.jpg (72.16 KiB) Viewed 8833 times
- jri6.jpg (109.47 KiB) Viewed 8804 times
Jointech add-on's
This next bunch of 12 photos have to do with add-on's for the Jointech system. Again these are Jointech items but you may find some ideas that you could build for your system based on what you see here. If nothing else think of it as general education.
Table Featherboards
[ATTACH]2856[/ATTACH]
Normal and Jumbo Faceplates (the jumbo is the add-on)
[ATTACH]2857[/ATTACH]
VPF Coping Kit
[ATTACH]2858[/ATTACH]
VPF Guard on Fence a bonus feature
[ATTACH]2859[/ATTACH]
Fence Raiser
[ATTACH]2860[/ATTACH]
7 more to go on this subject.
Table Featherboards
VPF Coping Kit
Fence Raiser
- jao1.jpg (106.86 KiB) Viewed 8815 times
- jao2.jpg (99.96 KiB) Viewed 8821 times
- jao3.jpg (127.92 KiB) Viewed 8803 times
- jao4.jpg (110.02 KiB) Viewed 8809 times
- jao5.jpg (103.33 KiB) Viewed 8804 times
Jointech add-on's
Rear view of Fence Raiser
[ATTACH]2861[/ATTACH]
Mounting Brackets
Adapt fence to router tables, comes in two sizes
[ATTACH]2862[/ATTACH]
Brackets in use, almost and on the old OPR
[ATTACH]2863[/ATTACH]
Brackets on OPR
This is mounted backwards to shows how the brackets work
[ATTACH]2864[/ATTACH]
Fence Featherboard, having more then one might be nice??
[ATTACH]2865[/ATTACH]
Just 2 more in this collection.
Mounting Brackets
Brackets on OPR
- jao6.jpg (93.61 KiB) Viewed 8807 times
- jao7.jpg (89.67 KiB) Viewed 8802 times
- jao8.jpg (104.02 KiB) Viewed 8798 times
- jao9.jpg (139.98 KiB) Viewed 8803 times
- jao10.jpg (101.43 KiB) Viewed 8807 times
Jointech add-on's
Hold Down Clamp, small and helpful
[ATTACH]2866[/ATTACH]
5-pc Ring Set
[ATTACH]2867[/ATTACH]
That is all that I have at this time but I do want one more item... it made the budget cuts so just maybe I'll have something else to add???
5-pc Ring Set
- jao11.jpg (90.38 KiB) Viewed 8800 times
- jao12.jpg (102.92 KiB) Viewed 8806 times
- pinkiewerewolf
Ed, I don't know if we've told you this lately but...
You ROCK!
You ROCK!
John, aka. Pinkie. 1-520, 1-510 & a Shorty, OPR. 520 upgrade, Band Saw, Jig Saw, scroll saw, Jointer, Jointech Saw Train.
Delta Benchtop planer, Makita LS1016L 10" sliding compound miter saw, Trojan manf. (US Made)Miter saw work center, MiniMax MM16 bandsaw.
Squire of the Shopsmith. ...hmmmm, maybe knave, pawn, or wretch would be more appropriate for me.
Jointech plus information
Two more post coming up on some information on the jointech system relating to questions about how it works. Didn't want to loose these.
[ATTACH]2868[/ATTACH]
[ATTACH]2869[/ATTACH]
[ATTACH]2870[/ATTACH]
[ATTACH]2871[/ATTACH]
[ATTACH]2872[/ATTACH]
Few more pictures to follow
- jpinfo1.jpg (149.95 KiB) Viewed 8811 times
- jpinfo2.jpg (143.4 KiB) Viewed 8805 times
- jpinfo3.jpg (153.84 KiB) Viewed 8804 times
- jpinfo4.jpg (150.54 KiB) Viewed 8796 times
- jpinfo5.jpg (142.48 KiB) Viewed 8797 times
[ATTACH]2873[/ATTACH]
[ATTACH]2874[/ATTACH]
[ATTACH]2875[/ATTACH]
[ATTACH]2876[/ATTACH]
OK that is that. Another bunch added
- jpinfo6.jpg (104.32 KiB) Viewed 8795 times
- jpinfo7.jpg (160.22 KiB) Viewed 8800 times
- jpinfo8.jpg (158.13 KiB) Viewed 8793 times
- jpinfo9.jpg (108.88 KiB) Viewed 8796 times
Re: Jointech items in photos
Hey had a couple questions about jointech
