Mark V -- Keyless Drill Chuck Adapter
bucksaw
Post by bucksaw »
I'm thinking of selling a drill chuck adapter for a Mark V that would sell for about $30 - $35 and would support JT33 taper for drill chuck mounting. I could offer keyless chucks as an option. This would give you a easy way to mount a JT33 keyless chuck.
Any interest?
Dave - Idaho
"Why do we drive on parkways and park on driveways?" :cool:
gregf
Post by gregf »
An adapter to be able to use other chucks sounds interesting.
Richwood, OH
There is no such thing as an unsafe tool, only unsafe owners. If you make a machine idiot-proof, God will invent a better idiot.
billmayo
Post by billmayo »
bucksaw wrote:I'm thinking of selling a drill chuck adapter for a Mark V that would sell for about $30 - $35 and would support JT33 taper for drill chuck mounting. I could offer keyless chucks as an option. This would give you a easy way to mount a JT33 keyless chuck.
Any interest?
I have several keyless drill chucks that came with some Shopsmiths I brought. Since these 5/8" ID adapters puts the drill chuck a longer distance from the headstock, when there is any play in the quill bearing(s), it is diffficult to start and/or keep the drill bit centered. Also, I could not secure the drill bit as tight with the keyless drill chuck.
If your adapter can fit inside the drill chuck and can be secured over the quill shaft to where the drill chuck sets in about the same position as the original Shopsmith drill chuck, then there may be a market for this adapter. I was unable to machine one with my metal lathe that I felt safe using. I believe you can buy a keyless drill chuck from Jacob that fits the Shopsmith.
bucksaw
Post by bucksaw »
The adapter would probably add about 1/2 - 3/4 inch to the overall length of the current chuck. I'll have to play with it. I've got a greenie that I'll finish the overhall on once all the replacement parts show up which will still have a single bearing quill and I'll be able to test.
Bill, do you know what jacobs model? I've done some searching on the Jacobs site and don't find any shopsmith chucks listed or any chuck for that matter with a female 5/8" straight mount.
Thanks for the feedback.
Dave - Idaho
a1gutterman
Post by a1gutterman »
billmayo wrote:I have several keyless drill chucks that came with some Shopsmiths I brought. Since these 5/8" ID adapters puts the drill chuck a longer distance from the headstock, when there is any play in the quill bearing(s), it is diffficult to start and/or keep the drill bit centered. Also, I could not secure the drill bit as tight with the keyless drill chuck.
Maybe they used to, they do knot any longer. This is post 9 from thread https://forum.shopsmith.com/viewtopic.php?t=2791&highlight=jacobs+chuck:
Well, I got a response from Jacobs Chuck:
Quote:
[align=left]Tim,
[align=left]We currently do not make an MC8K26 or any other Multi-Craft chucks with 5/8" straight taper mount w/ set screw.
The only keyless solution that I can think of is making a very short adaptor. Take a 3/4" to 1.0" diameter bar stock and bore a 5/8" hole on one end and turn / thread the other end w/ 1/2"-20 threads. Make the adaptor about 1.5 to 2.0" long.[/align]
[align=left]If you make this adaptor, then you could purchase a keyless chuck at most hardware stores or home improvement stores.[/align]
[align=left]Thanks,
Mike [/align]
[align=left]What Mike suggested sounds a lot like what Bill Mayo says that he has found on some SS's. If I get a round-2-it, I might just visit my local machine shop and see what it wood take to create this adaptor. A keyless chuck might be nice, but it is knot high on my priority list.[/align]
[align=left]Quote:
Originally Posted by billmayo
I have a few keyless drill chucks from the Shopsmiths I buy. The last one was a keyless drill chuck with a 1/2" thread that someone used a short 5/8" arbor (non-shopsmith, but like the shaper arbor) with the 1/2" drill chuck threads and put the two together.[/align]
[/color]
"Mike" is Mike Goodson with Jacobs Chuck. Here is his e-mail: Goodson, Mike [mgoodson@jacobschuck.com]Good luck. I did knot have any!
[/align]
Tim
